Schumacher's new K2 4wd buggy ..! >
Like Tree27Likes
    Hide Wikipost
Old 08-11-2016, 07:12 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Schumacher's new K2 4wd buggy ..!
Last edit by: AmiSMB
Welcome to the Schumacher K2 Wiki!
Please feel free to add tips and tricks as well as any information that you would feel is beneficial for everyone to know.
Introduction and Pictures Introduction and Pictures
ElectronicsSetupElectronicsSetups
Setup SheetsSetup Sheets
EmulsionShocksEmulsion Shocks
Tony Newland Gear Diff BuildTony Newland Gear Diff Build
Help I Keep Breaking Front Arms
With the K2 Schumacher sarted using an adjustable hub design that required
a relief cut in the arms for the steering knuckle to clear. The easiest solution
until a revised arm is to run the old style arms without the relief cut. Run the
hubs in the High position and set your steering end points down so the steering knuckles don't hit.
SCHU3597
SCHU3407 MED Flex
There is a newer batch of the SCHU3407 wishbones which correct the weakness in the previous front arms.
Suggested upgrades/spares
Strongly suggest to buy 10° alloy front alloy pivot blocks-U3556 the A & B front plastic pivot blocks-U4798 will break soon.
Have some shock seats spares, alloy v1-U3611, plastic-U3937, alloy v2 (off-road)-U4890
Have some spare shock shafts available U3668 & U3669
MIP pucks an Excellent option!
Misc
Other wheels that fit apart from the Schumacher wheels
Losi 22-4 wheels will fit on the front the rears will work as well!
AE b4, b5 & b6 will fit on the rear
Be sure to lock tight the track screws and rear strap this is a must!!!
AE (12mm) and KYO fronts will work with .5mm spacer - available through AVID
Don't buy the purple titanium turnbuckles as an upgrade there thread is too small and they wander too much. Lunsford Super-duty titanium turnbuckles fit very well they are 3.5mm threads. Get the 1 3/4", 2 1/8" & 57mm lengths. I did not replace the Centre Track Rod.
** When running the Super Duty turnbuckles with the stock captured ball ends, be sure to check for binding in the front steering and camber links after each run - tumbles and glances off the pipes cause them to flex and slightly twist and can bind up the front suspension ... The fix? - simply take a turnbuckle wrench and twist the link back and then forward to it's original positon .. consider doing this as a maintenance step after each run ..
Suggested Gearing
5.5 - indoor high bite clay 83/20 (+/- 1 tooth for layout and conditions etc)
6.5
7.5
8.5
9.5
10.5
13.5 At SRS Arizona I ran 75/28 buggy was quick! RCM lockout worked great!
17.5 - FDR between 5-6 depending on track. E.g. 35/66 down to 30/69 slipper eliminator in use. Different options within the thread. I use B5M exotek eliminator and file it to fit.
Print Wikipost
Old 11-05-2015, 01:59 AM
  #46
Suspended
Originally Posted by scoobyrs25
Weeks ago Schumacher said on their website that in a few days.they would announce the car. Still waiting......
Perfection takes time, this is going to be bad ass when it comes out!
Cmgreen is offline
Old 11-16-2015, 07:35 AM
  #47
Xyzzy's Avatar
Trader Rating: 32 (100%+)
https://www.youtube.com/watch?v=MROHdMoM9II
Xyzzy is offline
Old 11-16-2015, 08:13 AM
  #48
Trader Rating: 9 (91%+)
Its on their website now:
http://www.racing-cars.com/pp/Car%20...m/CAT_K2.html#
leongkc is offline
Old 11-16-2015, 08:20 AM
  #49
the incubus's Avatar
Trader Rating: 17 (100%+)
Dear goodness, could he be any more boring and timid sounding?
I find it to be a Meh overview of the NEW product.
Still I can't help but have Heart eyes when I see this thing. LOL
the incubus is offline
Old 11-16-2015, 08:46 AM
  #50
pchroma24's Avatar
Trader Rating: 83 (100%+)
Updated first post with access and details .. .. Please PM with any pertinent or needed details etc and I will include them on the first post as this develops..
pchroma24 is offline
Old 11-16-2015, 08:57 AM
  #51
Did you expect him to shooting guns into the air &'saying yehaw to make it sound more exciting? He's a bloody good lad is Trish, dead friendly & helpful, even if you don't run a Schumacher. Bloody good driver to.
John Myall is offline
Old 11-16-2015, 09:12 AM
  #52
Chillax there a bit… I LOVE this car.
Nice guy or not, I just think a product such as this deserves a bit more pizazz. There's a lack of passion in the presentation. Is it so wring to say so? Geeze Louise.
Old 11-16-2015, 05:31 PM
  #53
I'd rather them spend the money on R&D than marketing any day.
scoobyrs25 is offline
Old 11-16-2015, 05:34 PM
  #54
I don't know how I'm going to build it without the wife seeing it
Old 11-17-2015, 12:43 AM
  #55
Suspended
Looking good Schumacher, they went well at the weekend, some very nice features!
Cmgreen is offline
Old 11-17-2015, 07:46 AM
  #56
Red face
Same here...!
micholix is offline
Old 11-17-2015, 02:02 PM
  #57
Originally Posted by micholix
Same here...!
Good luck with that! I don't know about them ball studs look's just like Serpent's ball studs which I hear have binding and breaking issue's? Maybe that's why there are so many washers which i think is a lot to deal with. I will replace them with lunsfords ball studs and Schuie ball cups never an issue with this!
MelKF2 is offline
Old 11-17-2015, 03:46 PM
  #58
Trader Rating: 15 (100%+)
I've purchased B5 studs (8mm and 10mm) and cups in advance, not knowing that the K2 would have these new captured ends, but I like them. I'll be ready to swap them for the AE set if they end up binding. I am also going to stick with the B44 wheels, I'll pick up U4321 and drill the centres out to the axle diameter and then glue in the 0.5mm spacers. I'm looking forward to getting my build on. This will be my first Schumacher since my 2000 Team Cougar!
HeavyD99 is offline
Old 11-17-2015, 04:04 PM
  #59
...I believe the photos available on petitrc are all taken before the new captured ball studs and cups were available or issued, but like anything else, time will tell!
HeavyD99 is offline
Old 11-17-2015, 04:05 PM
  #60
Well lets hope it works out, I have noticed that in all the picture's now posted on the fatory driver's buggy's they are not using the new ball stud's?
MelKF2 is offline
