Motor change generalities >
Old 09-11-2015, 11:55 PM
Default Motor change generalities
I have the Tower Hobbies "Cutback" (4wd SC). I want to change the Motor. Current(Factory) motor is a 3600kv,4 pole with a 11t pinion and 64t spur gear. Would like to go to a 5400kv, and keep the same spur gear. What should I change the pinion gear to so I don't fry the motor??....AGAIN.
redbaron344 is offline
Old 09-12-2015, 04:26 AM
Hoese37's Avatar
Something doesn't seem right. An 11t pinion and a 64t spur is a relatively high ratio, especially for a 4 pole motor. Sounds way undergeared.
Hoese37 is offline
Old 09-14-2015, 07:49 PM
Correction, the spur gear is 62T (32 pitch) center diff on a 4wd. This is out of the box gearing on this truck.
