Old 11-01-2005, 09:15 PM   #1
Default ae .15 engine
i need a rod for my .15 engine. which hobby shop have them in stock and other parts for the rc10gt truck. also, what radio would be a better upgrade from the stock radio and servos .do i have to stay with 27mhz or can i use 75 mhz. thanks jeff b.
jeff b. is offline   Reply With Quote
Old 11-01-2005, 10:56 PM   #2
Mustang2's Avatar
Send a message via AIM to Mustang2 Send a message via Yahoo to Mustang2
Here is the rod http://www2.towerhobbies.com/cgi-bin...?&I=LXUP79&P=0
Here is the part's- http://www2.towerhobbies.com/cgi-bin...GT&FVPROFIL=++
Mustang2 is offline   Reply With Quote
Old 11-01-2005, 10:59 PM   #3
Mustang2's Avatar
Do you want to go FM or AM ?
Here is a AM setup with 2 servo's
http://www2.towerhobbies.com/cgi-bin...I=LXCXM5**&P=0
FM setup with 2 servo's
http://www2.towerhobbies.com/cgi-bin...I=LXCHA7**&P=0
Hope this help's
Old 11-02-2005, 04:41 PM   #4
thanks mustang 2, i should have known tower is the one stop shopping place.
Old 11-02-2005, 06:19 PM   #5
WheelNut's Avatar
Send a message via MSN to WheelNut
Don't forget to try your local hobby shop. If its a half decent shop they will probably have them in stock, or can get them easily. Remember to have part numbers before you go in, so finding the parts is easier. They can also show you different radio's and get you setup with servos and such.
WheelNut is offline   Reply With Quote
Old 11-02-2005, 07:47 PM   #6
thanks wheelnut, how do i get the nut off of the crank that holds the clutch plate and the startergear on.i have to get the crank out so i can clean the bearings.
Old 11-02-2005, 11:57 PM   #7
Mustang2's Avatar
No prob.
Old 11-05-2005, 07:14 AM   #8
Team Duratrax's Avatar
Send a message via MSN to Team Duratrax
Definetely buy an FM radio system. AM radios are terrible with nitros.
75mhz and 27mhz cannot be mixed. It's best to use 75mhz though.
Team Duratrax is offline   Reply With Quote
Old 11-06-2005, 07:23 AM   #9
thanks guys, i have one more question. when i removed the bell housing or clutch plate (correct me if i'm wrong) two plastic peices fell off of the flywheel , can someone show a picture , so i will know how to put them back on. thanks. jeff b., and can i put the buggy tire and rims on my rc10gt.
Old 11-08-2005, 03:49 PM   #10
can someone help me, please.
Old 11-08-2005, 08:33 PM   #11
WheelNut's Avatar
Those 2 plastic piece are your clutch. My advice, throw them in the garbage and buy an MIP 4n1 clutch, it is a thousand times better. You will get more bottom end and your engine will idle alot better. The MIP clutch comes with instructions on howto install it. If you want to just run the stock clutch though basically all you have to do to install it is just slide the shoes onto the pegs sticking out of your flywheel. You need to put them on so that the clutch shoes engage on the trailing edge (note: your engine spins counter clockwise). To get the clutch nut off the crankshaft you will need to stop the piston from turning over. The easiest way to do this is to remove the exhaust header and glow plug and then insert a large/thick zip tie in through the glo plug hole and out through the exhaust port. Then you can loosen the nut off, to tighten it back up do the same thing and slowly tighten the nut until the zip tie gets cut through, at that point the nut will be tight enough. Make sure to use locktite on the nut as well. Also if you dont have the complete building manual for the GT I would highly recommend going onto AE's site and buying one (for some reason you cant download it! Although all the others are avaliable for download). The manual shows howto build the truck from the ground up.
Old 11-09-2005, 03:33 PM   #12
thanks wheelnut. where can i get the MIP 4n1 clutch set.
Old 11-09-2005, 08:33 PM   #13
bump
Old 11-12-2005, 08:06 AM   #14
Here you go: http://www2.towerhobbies.com/cgi-bin...?&I=LXAX13&P=7
Old 11-12-2005, 06:54 PM   #15
thanks guys this info realy helped me out alot thanks again
GO 28R/Full Starter Engine GRracing Ver.Team Fully Modified Engine handpiece Onroad Nitro Engine Zone 0 07-28-2007 03:42 AM
Ofna Picco .21B 3 Port engine, good budget engine Cain Electric Off-Road 1 03-26-2007 08:32 AM
selling custom savage roller with engine, truck zillia modded engine.$275 pat360xboxhalo3 R/C Items: For Sale/Trade 2 01-11-2007 05:23 AM
mugen mst1 with engine and pipe f/t for 1/8 buggy engine tony montana R/C Items: For Sale/Trade 5 08-22-2006 04:52 PM
Engine Temperatures for Break-In and Normal Use for XTM 24.7 Engine. Head Shims? racer rich Nitro On-Road 0 12-13-2002 11:49 PM
