Motor goes full throttle when car is turned off >
Old 08-30-2015, 05:51 PM
Default Motor goes full throttle when car is turned off
So, this is weird...but whenever I turn off my RC car the motor goes full throttle. It's not even when I turn off the TX. If I switch off the ESC it just starts going. It is a Novak 410 HPC, its a pretty old ESC but it just started doing this today.
darkspartan239 is offline
Old 08-30-2015, 05:58 PM
Regional Moderator
RobsRacin's Avatar
Did you try recalibrating it? With the ESC off it shouldn't be receiver any signal/electricity/anything
RobsRacin is offline
Old 08-30-2015, 06:08 PM
If one of the capacitors came undone would that cause the problem?
Old 08-30-2015, 06:13 PM
Nevermind...it didn't come undone.
Old 08-30-2015, 06:21 PM
So, I tried recalibrating it, and it is still doing it.
Old 08-30-2015, 06:27 PM
Does your Tx have a failsafe built in? On my MT-4 if the failsafe is set incorrectly it will go to full throttle when it's turned off
Tijuana_Taxi is offline
Old 08-30-2015, 06:32 PM
Yes, it does have a failsafe, I will try that.
Old 08-30-2015, 06:42 PM
That did not work either. I don't think its a Tx or Rx problem. I'm not sure what it could be.
Old 08-30-2015, 07:47 PM
Trader Rating: 14 (100%+)
Does the ESC work properly when it is on? If you are short on money I would just leave the switch on and unplug the battery to turn it off.. but the best solution would be to replace the ESC I think.
IOP_Racer is offline
Old 08-30-2015, 09:24 PM
Mine does the same thing when the car is on. No input from me and the motor will just go balls out. Interested in what the problem could be.
slashed is offline
Old 08-31-2015, 07:15 AM
Yes, it works perfectly fine when the switch is on. I guess I will just take your advice and do that!
Old 08-31-2015, 07:16 AM
Yeah, I really want to figure out what the problem is, just because I am that kind of guy. I like to see what went wrong.
Old 08-31-2015, 09:17 AM
Suspended
It's very likely something internal to the speed control. It's close to 20 years old. Can you name one electrical anything that you still use today that is that old?
J.Winnfield is offline
Old 08-31-2015, 12:10 PM
Rysuleod's Avatar
It's an ESC failure. I just had a LaTrax Rally ESC act the same way. It was off but plugged in and occasionally the throttle would blip.
Rysuleod is offline
Old 09-03-2015, 05:58 AM
My toaster is from 1953. My car is from 1965. My home stereo system is from 1990.
Scargoes is offline
