Team Associated's new RC8B3e >
Like Tree63Likes
Old 09-14-2016, 02:47 AM
  #901
Trader Rating: 33 (100%+)
bvrc , have you installed and set your droop screws on your arms? a local guy with a new losi kept having this problem and after inspection he hadnt installed his droop screws, fixed him right up.....
smoke229 is offline
Old 09-14-2016, 03:44 PM
  #902
jzone's Avatar
anyone wanting to sell their B6 to meeeee....
jzone is offline
Old 09-15-2016, 04:20 AM
  #903
TAW
Trader Rating: 18 (100%+)
Originally Posted by werner sline View Post
every arms bends when absorbing a crash. Some will flex back better. Worst arms I ever had were the mbx7r eco one ! I switched to xray xb8 arms ( you may do this too on your buggy ). They flex back very well but will stay curved after a while too.
I had hobao hyperstar arms too on my mbx7r eco : they flex very very well, as good if not better than the xray !
I posted this in the nitro thread and the response was we know about it and are looking for a solution. It was suggested to disconnect the front shocks while its being stored. I think whats happening is the droop screw is creating a pressure point, the shocks pushing down on that soft arm over time are allowing it to bend.
TAW is offline
Old 09-15-2016, 04:23 AM
  #904
TAW
Originally Posted by bvrc View Post
This is why I think its a setup issue... Anyone know tweaks that may reduce loosing shock ball ends?
Most important thing is to make sure your droop is less than the free length of the shocks. For instance, if your front shock are length is 108mm then your droop needs to be less than 108mm. I think the DNC sheet calls for 104. This keeps the arm from over extending and pulling the ends out.
I also think that due to the soft arms in a crash they can be overextended past where the droop is set and that will still pull them out.
TAW is offline
Old 09-17-2016, 10:26 PM
  #905
Finally built my new V2 diffs with updated shims. I must say they feel very good.
KyJoe340 is offline
Old 09-18-2016, 06:30 AM
  #906
Tech Legend
Cain's Avatar
Trader Rating: 256 (100%+)
Originally Posted by TAW View Post
... It was suggested to disconnect the front shocks while its being stored. I think whats happening is the droop screw is creating a pressure point, the shocks pushing down on that soft arm over time are allowing it to bend.
that sounds a whole lot like what we went through with the sc10 4x4 a-arms .
Cain is offline
Old 09-18-2016, 08:23 PM
  #907
The manual i was looking at online shows blue front and rear springs and green 2.4 / yellow 2.7 sway bars. Can anyone confirm this is what is actually in the kit?
My ST-RR EVO is offline
Old 09-27-2016, 12:58 AM
  #908
Does the Bitty Design Force body for nitro fit this eBuggy too?
Old 09-28-2016, 04:12 PM
  #909
Got a question about anti roll bars...
I was looking back at my manual after the build and noticed that the manual calls for black/2.4mm in the front and the gray/2.7mm in the rear. I looked at my car and it came with two blue/2.8mm bars for the front and rear.
Secondly, I am looking for some clarification. I notice when I look at the manual for both the b3e and the 44.3, that both vehicles call for a lighter bar in the front and a heavier bar in the rear. However, I am getting some advice from local racer telling me to put a heavier bar in the front and lighter in the rear. Does that sound right? Is there a situation that would call for this approach as opposed to the strategy that the manufacturer has taken with their box stock setup?
Lastly, what is the advantage of the V2 diff and does the new B3e and T3e kits come with the V2 diff or is that purely an upgrade?
Patt
freezeframe007 is offline
Old 09-28-2016, 06:26 PM
  #910
Trader Rating: 20 (100%+)
Side pods are too low. Won't fit over the battery worth a darn.
MX304 is offline
Old 09-28-2016, 11:07 PM
  #911
Thank you. Too bad though. I really like the way that Bitty body looks!
Old 09-29-2016, 01:05 PM
  #912
Default rc8b3e setup question
does any one have any info on front upper/lower arm mounting pos when making changes what affect does it have on the buggy. any charts i find are for camber links. nothing on upper control arm buggys
chuck c is offline
Old 09-29-2016, 11:56 PM
  #913
Raising or lowering the upper control arm on this buggy has the same effect as raising or lowering a camber link on a different buggy that used camber links. Raise the upper control arm or camber link and you get more roll.
The B3E's upper control arm and pillow ball front end allows for active caster too.
Old 10-16-2016, 06:57 AM
  #914
My son ran my car at a outdoor race, car was hooked up. Any major changes we should do for indoor racing?
smokefan is offline
Old 10-17-2016, 11:05 AM
  #915
TomErickson's Avatar
What bodies fit this car? I am looking to replace both my Nitro and Electric B3 bodies. Bittydesigns and Jconcepts only have nitro covered. What about the eBuggy?
TomErickson is offline
