Old 10-30-2005, 02:53 PM   #1
Default Losi XXX 4G plus with Brushless
I'am buying a Losi XXX4 G plus and I want to put the Novak supersport plus Brushless system in it. Will this work, will there be any any problems?
Losi boy is offline   Reply With Quote
Old 10-30-2005, 04:14 PM   #2
i run one all the time..just go to www.teamnovak.com and check their gearing page to check for the proper gear ratio.
otherwise they just fly with the brushless
colaman24 is offline   Reply With Quote
Old 10-30-2005, 05:28 PM   #3
eri3f0g's Avatar
Trader Rating: 14 (100%+)
I've got one with the ss5800 in it. Fantastic running! I tuned down the brakes a bit and other than that just learn some throttle control. Sails nicely on the jumps. I can't say if that's due to the brushless as I've never run a brushed motor in it but the way the brushless freewheels it's awesome. A light tap to the throttle or brake in the air gives instant feedback..
Enjoy.
Associated FT B4.1; SC10; T4
All tekin RS 17.5; RSPro 10.5; RS 13.5
All Savox 1258TG's (power caps on rx's)
DX3R w/ SR3100's & Gens Ace Batteries
Now, to be able to drive, priceless
eri3f0g is offline   Reply With Quote
Old 10-31-2005, 08:24 AM   #4
Davidka's Avatar
Trader Rating: 77 (100%+)
Two tips, if you run on a high grip surface the amp draw can be very high. Some of the racers in my area found that they needed to put vents in the body over the speed control to keep from thermalling. Also the 5800 has a very bottom heavy throttle curve. I found that I could change this by turning my Exponential adjusment down to 60%. This makes the cruve feel more like a conventional setup. I recently changed to the GTB and it's even better.
Old 10-31-2005, 11:00 AM   #5
Davidka
Did you have any problems fitting your GTB in the xxx4?
tinbndr is offline   Reply With Quote
Old 10-31-2005, 12:38 PM   #6
eri3f0g's Avatar
I second that... My 5800 does get hot. I can make a five minute race no problem but I can't kick a battery pack without a cool down period. As stated it also depends on track layout/grip.
tnbndr: I would assume the GTB to fit easily in the xxx4 as the stock ss5800 esc is larger and I've got it intalled.
ss5800 esc:
1.32" wide
1.75" long
GTB esc:
1.16" wide
1.49" long
Old 10-31-2005, 12:55 PM   #7
I am worried about the height with the Fan on it.
Old 10-31-2005, 01:25 PM   #8
Davidka's Avatar
Hmm that would be close. I know that the BK2 needs the body cut away to clear the fan but I have never used the fan on mine. It is mostly for carpet touring car use. I would mount it without the fan first. If your surface is extremely high grip you may need the fan but I ran on a offroad track where throttle control is about keeping the front wheels on the ground and had no heating problems.
The only difficulty about mounting these is the keg of a power capacitor that it has pt be run with. It does not tie on to the side as it did with the GT7.
You should be ok without the fan as long as there are some venting slots over the speed control.
BRUSHLESS LOSI TYPE R W/ SPEED PASSION GT/13.5 AN ORION LIPO 4800 I NEED A LOSI 8 DENNIS STORTI R/C Items: For Sale/Trade 1 05-04-2008 09:42 AM
brushless, spektrum receivers, charger, brushless losi 8 tschenck R/C Items: For Sale/Trade 17 04-08-2008 07:18 AM
XXX-T CR brushless GTB LOSI Losiguy99 R/C Items: For Sale/Trade 5 02-27-2008 05:54 PM
new losi brushless esc morris Radio and Electronics 1 12-24-2007 04:34 PM
B]Losi BK2 Brushless[/B] ebhome R/C Items: For Sale/Trade 2 05-01-2007 04:59 PM
