Slow Velenion?
Old 08-11-2015, 04:28 PM
Default Slow Velenion?
So I sold my friend my used Velenion brushless motor and ESC from my 44 Slash and he put it in his Slash 2wd and its barely faster then the stock brushed motor, we checked to make sure it was in lipo mode and the gears and everything were meshed properly but its still really slow and we have no idea why. When it was in my Slash it was going fine, I even tested it the day before he swapped the motor to make sure it ran fine. Anyone know what could have gone wrong?
AmericanMan007 is offline
Old 08-11-2015, 07:17 PM
is it faster in reverse, made this mistake before....
Rob4607 is offline
Old 08-11-2015, 11:52 PM
tsair's Avatar
Maybe he's in training mode on his ESC or transmitter? It cuts power by 50%.
tsair is offline
Old 08-12-2015, 03:39 AM
n2mini's Avatar
What he said ^^^^
n2mini is offline
Old 08-12-2015, 06:40 PM
Why yes it is, what do you think it is?
Old 08-12-2015, 07:05 PM
Reverse two of the three wires at the esc from the motor and give it a shot. I scratched my head the first time on this....
Rob4607 is offline
Old 08-12-2015, 07:54 PM
But the wires are matched up? So shouldn't it work as is?
Old 08-13-2015, 01:18 PM
Trader Rating: 23 (100%+)
I had the same thing happen with a Velineon system and switched the 2 wires and it worked fine. You may reverse the throttle setting on the radio if it is capable, that may be why switching the wires might help. I also had something else happen to my sons car recently...take a look at your radio. The throttle end points may be set waayyyyy low and reducing power to the system. My son has one of the cheaper radios with the twist dials so it happens relatively easily but I would check both two.
onceaday is offline
