MIP Shiny Drive Pucks Problem >
Old 08-06-2015, 09:59 AM
Questions?? MIP Shiny Drive Pucks Problem
I bought the MIP Pucks kit for my Sc10 and when trying to install the diff into the diff case the outdrives will not fit through the bearings that sit in the diff case. Do I have to buy different bearings to fit the MIP diff? Or am I missing something else? Thanks for your guys help
Spleen is offline
Old 08-09-2015, 02:22 PM
rustyus's Avatar
10 x 16 mm bearings are needed.
rustyus is offline
Old 08-09-2015, 04:00 PM
trevcoll's Avatar
All SC10 kits or RTR came with the 10X16mm bearings. It is possible that someone may have put a B4 (not a .1 or .2 as those had the 10X16 bearings) gearbox into a RTR to add a ball diff upgrade. If you've got 3/8 X 5/8 outdrive bearings you've got a couple of choices. Plan A is get 2 10X16mm bearings and a 9826 gear case. Plan B is get MIP 14121 & 14122 (13.5 & lower wind) or 14252 & 14253 (17.5 aluminum) and keep your existing case and bearings. The parts from plan B are intended for X-Factory cars that still use the old style diff. Plan A would be my choice from both a cost and availability standpoint, unless of course you plan on picking up a SCX-60/61 mid motor conversion.
trevcoll is offline
