Stripped wheel hex?
Stripped wheel hex?
I stripped out the screw on the wheel hex on my XB4 and was going to drill it out but didn't know if anyone else had any other tricks?
This is the part I'm talking about: http://www.amain.com/rc-cars/exotek-...409blk/p441104
Thanks!
Thanks!
Tricky one that, I'd try to pry it off with a flat screw driver, when off it should loosen up if you push the hub together.
These work awesome. Used more than a few times and have always worked. Bought mine at Ace hardware.
http://www.amazon.com/Alden-4507P-Gr.../dp/B000Q60UOO
I may try that...Just use an old soldering tip?
Thanks! I got it off by heating it up with the soldering iron and prying it off...It took some effort but was able to get it off without breaking anything else
