Hot Bodies D216 1/10 2WD Buggy! >
Like Tree76Likes
Old 02-15-2019, 07:18 AM
  #1336
I used a xray idler in mine....bearing od was smaller but the id was the same worked like a charm and didnt need to change gearing
ahe243 is offline
Old 02-15-2019, 09:00 AM
  #1337
mes
Originally Posted by JRSlash View Post
Mine is getting a little loud now and looked into putting this b5m idler but couldn't find it. All I could find was the hardened steel one....
AE91429 seems to be discontinued, but may be still available e.g. on ebay. IIRC the original Yokomo YZ2/YZ-4 idler #Z2-503I dimensions are identical.
By the way, the number of teeth on an idler gear does not matter at all. As long as the topshaft and diff gear are the same, the transmission's internal gear ratio will remain the same. Just take a look at AE's laydown and layback transmissions, they are both 2.6:1 and use the same internals except for the idler gear.
JRSlash likes this.
mes is offline
Old 02-15-2019, 05:50 PM
  #1338
I read that the stock idler gear is prone to breaking. Have you guys had the same experience?
Lukeman269 is offline
Old 02-17-2019, 10:27 AM
  #1339
yep it's the material it's made of i think. i never bothered using mine it sits in the box as a backup spare for the unlikely event of needing it. I have just picked up a spares car which was std internals and chewed up idler in place still so confirmed for me that it is a 'thing' stripping the std one.
chrisimp is offline
Old 02-17-2019, 12:39 PM
  #1340
Default Idler gear
Stay away from the aluminum idler gears. They will sharpen the teeth eventually stripping the diff gear.
HBracingRy is offline
Old 02-17-2019, 12:41 PM
  #1341
I use the sepernt idle gear. Comes with 2 in a pack. I run my cars hard and they still look new.
Old 02-18-2019, 11:06 AM
  #1342
Trader Rating: 28 (97%+)
Are they a drop in fit or do you have to mod them or run different bearings or ect?
party_wagon is offline
Old 02-18-2019, 11:38 AM
  #1343
Could you post a link or the part number please?
Old 02-19-2019, 06:15 AM
  #1344
JRSlash's Avatar
I just installed a Robinson racing steel idler for the b5 car. The gear is 1mm wider which I shaved the molded shims of the gear case and shimmed the idler as needed. Transmission is super smooth and quiet now. Note that the RR idler uses different bearings that are the same size as the top shaft.
JRSlash is offline
Old 02-19-2019, 01:14 PM
  #1345
Default Serpent srx mh 3 gear
Serpent # SER500525. You will need new bearings. There the same size as a nitro clutch bell if you have any spares. I think there 5x10x4mm.
Old 05-07-2019, 12:20 AM
  #1346
mustangkillaz's Avatar
I'm trying to get more mid corner and under acceleration steering. What have you guys had luck with. I've tried shocks and alignment mods, and some weight on the front end. Anyone able to get this thing to swing around any better?
mustangkillaz is offline
Old 05-08-2019, 05:08 AM
  #1347
Never had issues with swinging around the center point. What surface are you on? how is slow speed turning, can you afford to remove grip from the rear to allow the rotation to be increased (harder springs, roll bar 1.4, stiffer oil to stop the lean, top link position/washer spacing) battery inline or sideways. I mainly run on high grip and have to run a front roll bar to limit the amount of turn sometimes.
One thing at a time, each round and see what effect the change made, one thing Ive found about the d216 is the smallest change can make a great difference so easy to go to far one way or the other.
Another thing I found felt nice was to increase the width/track of the front by adding 2mm spacers to the wishbone mounting points on the bulkhead. also I run 20k diff oil pretty much everywhere now!.... Ball diff might be in for the weekend if it arrives in time for me to build it so that will be interesting to see the changes!
Edit: I also run the std chassis now with brace washers turned upside down and a b6.1D waterfall/chassis brace on the transmission which has locked down the rear end so not asmuch flex there allowing the suspension at the rear to do the work and the front flexes more for the front end traction etc
Chris
chrisimp is offline
Old 05-08-2019, 01:20 PM
  #1348
Chris
Thanks for the input, Chris.
I'm on med to high traction clay. I'm now noticing that my vrp pistons have less blow by than stock and I need to do thinner oil. I'm using 15k in the diff IIRC, but am gonna put some heavier stuff in, that's helping swing the back out and around under power. I'm also gonna add a little more front droop, that might help mid corner, on power push.
I'm on the hb alum chassis. I also have the exotek battery bracket arm.
Cg changed with arms are pretty much my next move. May add a little more camber in the rear, too.
Old 05-13-2019, 05:30 PM
  #1349
I do enjoy the ball diff. I would recommend it if you have some extra cash. Feels really locked in on med/high bite clay. I have used it outdoors on loose dirt as well with good results. Feels like it has better forward bite with the ball diff.
