Hot Bodies D216 1/10 2WD Buggy!
#811
any news if they will come out with a carpet version?
#812
Until absolute hobbyz gets stock in for the d216 you'll be hard pressed to find one in the US.
Why not order from ANSWER-RC in the UK?
HB204039 is the part number.
I just placed an order from Answer rc and the shipping is cheaper than usa-canada........ hahaha
or order direct from exotek.......
D216 FLITE TOP GEAR, 7075 - Exotek Racing
#814
Exotek does not make an aluminum idler, only HB. I have one that I would part with. I had it installed and ended up chewing up the diff gear so for me I didnt fix anything. It's much easier and cheaper to replace an idler gear instead of the diff gear.
TTR_RACER if you want it send me a pm with your address
#815
D216 with laydown transmission?
Looks like Ronnefalk is using some laydown transmission on the D216 (if it can still be called that )
+ https://youtu.be/meKt7lOJ82M?t=31" title="View this video at YouTube in a new window or tab" target="_blank">YouTube Video | |
#816
he says in video car is a prototype, and mentions a ball diff
#817
Hi All,
Help required for spur.
Need to run FDR 6 not any lower. Local Comp rules must not be under 6 for using 21.5 motor.
I need something like 72/29 or 69/28
Checked AE, TLR, Kyosho, X-ray and others they don't fit. HB slippers centre hole is 5mm and most of others are just under 5mm.
I've searched Exotek site but I can't find anything.
Anybody know any manufacturers that make same size centre hole as HB?
#819
hb
i think you might have to use the exotek slipper eliminator they do
the 69 and 66 spurs which would be suited for 21.5
cheers rob
cheers rob
#820
So I need to buy a direct spur mount and either the Exotek or Kimbrough spurs.
Was hoping someone made spur gears for HB.
Dame it. Why did HB choose to be different from most other manufacturers.
#822
#824
from my understanding there should be a kit in the future to update the car to laydown. I'd expect a new chassis,rear tower and trans.
