1200kv motor?
#16
is it enough to having a good performance?
#17
With 6S and a modest gearing (16T?) I guess there will be a big grin on your face
#18
Isn't sensored/sensorless determined by the speed control, not the motor? Fairly sure there are examples of both type of speed controls, some can even be switched between modes if I'm not mistaken.
#19
In a 1/8th scale, by the time the car is moving about as fast as you can walk, it is already running in sensorless mode and won't switch back unless you crash or stop for some reason. So if you run a 10 minute main with your RX-8 powered e-8 and don't crash or stop, you are running sensorless for 9 minutes and 59 seconds.
