Tekno RC EB48.3 Thread > Tekno RC EB48.3 Thread
Like Tree22Likes
    Hide Wikipost
Old 03-13-2017, 12:03 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC EB48.3 Thread
Last edit by: MattDub
Welcome to the EB48.3 Wiki
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
Springs:
Low Grip Track:
TKR8772 Yellow Low Frequency Rear Springs and TKR8762 Grey Low Frequency Front Springs
Low to Medium Grip Track:
TKR8773 Orange Low Frequency Rear Springs and TKR8763 Black Low Frequency Front Springs
Medium to High Grip Track:
TKR8774 - Red Low Frequency Rear Springs and TKR8764 - Pink Low Frequency Front Springs
TKR5199B HRC Rear Hubs (L/R, CV or uni, EB/NB/ET/NT48/48.3) - Improves stability of the rear on mid to corner exit. Able to be on power earlier on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6017T (front)
-TKR6061T (rear)
This car is very durable. Here are the spare parts that I recommend you keep on hand:
TKR5020 Hinge Pins (inner, front/rear)
TKR6061T Rear Shock Shafts w/ TiNi Coating and TKR6017T Front Shock Shafts w/ TiNi Coating
TKR5286 Front Suspension Arms and TKR5184 Rear Suspension Arms
TKR5194 Spindle Carriers
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Page 3 Step K-3
Put the screw in upside down so that the head of the screw is in the hex spot that's molded into the spindle. This will aid in clearance in full droop / full steering.
Page 12 Step I-2
Use no less than 4 shims on the steering spindle to limit steering throw. I actually just use one 2mm ball stud washer from my 10th scale stuff since each shim is .5mm.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Old 09-14-2015, 08:46 AM
  #316
snwchris's Avatar
For the .3 parts yes the bearings are the same front and rear.
Front Spindle Inner Bearing TKRBB13194 13x19x4 (same as rear hub)
Front Spindle Outer Bearing TKRBB08165 8x16x5 (same as rear hub)
The .2 Spindle used a TKRBB08144 8x14x4
snwchris is offline
Old 09-17-2015, 02:45 PM
  #317
MOE
MOE's Avatar
Trader Rating: 14 (100%+)
Originally Posted by rcgod View Post
If anyone wants to run universals on their buggy, sworkz 92.5mm are a direct fit. They are centered in the outdrives like stock so anything within about 1.5mm should work, like kyosho, mugen etc. Mbx7r front universals are 91.5mm and kyosho are 91mm so either should work.
Have you had a chance to try this out yet?
MOE is offline
Old 09-17-2015, 03:40 PM
  #318
rcgod's Avatar
Trader Rating: 27 (100%+)
Just got the kyosho universals yesterday. Perfect length. Only problem is the hole for the hex pin is 2.5mm and tekno pins are 3mm. Options are to drill out the hole or buy kyosho hexes and pins. In the process of drilling mine out but kyosho hexes are in stock at dollar hobbyz for $4 a set. Will try them out this weekend.
rcgod is offline
Old 09-17-2015, 07:33 PM
  #319
vwduud's Avatar
Trader Rating: 48 (100%+)
What size pin do the SWorkz axles use? 2.5 or 3mm?
vwduud is offline
Old 09-17-2015, 07:49 PM
  #320
rcgod's Avatar
3mm
rcgod is offline
Old 09-17-2015, 09:56 PM
  #321
vwduud's Avatar
3mm
Did you get the Kyosho universals just to try them, or did you feel they were better than the SWorkz?
vwduud is offline
Old 09-17-2015, 10:33 PM
  #322
rcgod's Avatar
Already had them for my sworkz ebuggy. Took them off to see if they fit the Tekno. I think the kyoshos fit better the universal is more centered in the pivot area of the front hubs than sworkz. And they're cheaper.
rcgod is offline
Old 09-18-2015, 07:34 AM
  #323
cpt_RedBeard's Avatar
Trader Rating: 22 (100%+)
When I ran universals I ran the Kyosho unis and Kyosho hexes. I didn't care for them. They made the car transfer weight weird. The car drove around the track dragging its rear around. That was early tho. I'm interested to see what comes up now that people have had the kits and setups have evolved.
cpt_RedBeard is offline
Old 09-18-2015, 07:37 AM
  #324
rcgod's Avatar
I pretty much expect something like that to happen until I can get some time tuning it on the track because of the differences between unis and cvds when under load.
rcgod is offline
Old 09-19-2015, 07:14 PM
  #325
Finally made the decision to fulfill one of childhood desires, getting my own 1/8th scale buggy, slight twist since there will be no nitro powering this one.
Local hobby shop, Nor Cal Hobbies, made a great deal on a package buy and before I knew what I was doing, I said "Order it up!"
Sadly, it has to come out West from the East coast or midewest warehouse so I might have it by Friday if all goes well. Nearly bought a 48SL but in the end the idea of all the upgrades for a slight bit more money won me over, thanks Rcgod!
Having read through most of the Tekno threads I have a feeling for the brand and what things to look our for so I had a strong list of items that should serve me well for our 2S indoor track.
- Tekno 48.3 Buggy
- Tekin Pro4 HD 4,300 KV
- Tekin RX8 Gen 2
- (2) Trinity 100C 2S 7,700 MAH lipo
- Savox SB-2282SG
- Proline Electrons, inserts and wheels
- Tekno Aluminum Servo Horn
I was not sure what pinion to have them set aside, I was guessing in the 16-19 range but not certain. What would folks suggest for a fairly small indoor clay track on 2S? I am also ordering the delrin shock internal set and probably some extra diff silicone oils to play with the power distribution. I will build everything else bone stock until I know what it may need for the track I run on. Anything else folks would suggest looking at prior to spending the time it takes to get it built?
Fasttrak is offline
Old 09-20-2015, 05:34 AM
  #326
I'd order a few extra screws for the diff cases. I've had a few strip and if you're going to be playing with your oils I'd make sure they are in good shape every time you put the diffs back together.
SpongeX is offline
Old 09-20-2015, 01:41 PM
  #327
rcgod's Avatar
- Tekno 48.3 Buggy
- Tekin RX8 Gen 2
- Savox SB-2282SG
Congrats. I don't think you'll be dissapointed. This is an awesome buggy.
rcgod is offline
Old 09-20-2015, 07:30 PM
  #328
Been racing my EB48.3 indoors lately and I have struggled with this vehicle the most out of any of my Tekno line up. Week by week I'm making small adjustments which seem to help bit it's not as dialed as my ET48.3 or SCT410.E yet. I have to drive it pretty aggressively and get it sliding around to do 180 degree turns well. I'm also getting wheelies when powering on after a jump, not sure if this is a suspension set up issue.
Riflebuilder is offline
Old 09-20-2015, 07:52 PM
  #329
rcgod's Avatar
What setup are you running?
rcgod is offline
Old 09-20-2015, 09:29 PM
  #330
It sounds like the track I will be running on will be quite similar to what you are experiencing. I will be very interested in hearing your current setup as I should be building my buggy by the end of this week.
Very new to three diff setups using silicone opposed to ball diffs. Having poured over multiple mfg of indoor clay track setups, I found the Tekno a bit lacking for setup sheets so stole from some other mfg, I am thinking of building my kit with a heavy front weight bias. I believe the kit comes with only 5K weight, I plan to grab most weight between 3K and 10K to play with on and off power steering. Our track is pretty small with lots of sharp turns and a few 180's. The new setup even has a massive banked sweeper that was giving some drivers fits for on power steering.
Does anyone have a good resource for tuning with silicone oil in 1/8th scale buggy differentials?
Fasttrak is offline
