    Hide Wikipost
Old 03-13-2017, 12:03 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC EB48.3 Thread
Last edit by: MattDub
Welcome to the EB48.3 Wiki
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
Springs:
Low Grip Track:
TKR8772 Yellow Low Frequency Rear Springs and TKR8762 Grey Low Frequency Front Springs
Low to Medium Grip Track:
TKR8773 Orange Low Frequency Rear Springs and TKR8763 Black Low Frequency Front Springs
Medium to High Grip Track:
TKR8774 - Red Low Frequency Rear Springs and TKR8764 - Pink Low Frequency Front Springs
TKR5199B HRC Rear Hubs (L/R, CV or uni, EB/NB/ET/NT48/48.3) - Improves stability of the rear on mid to corner exit. Able to be on power earlier on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6017T (front)
-TKR6061T (rear)
This car is very durable. Here are the spare parts that I recommend you keep on hand:
TKR5020 Hinge Pins (inner, front/rear)
TKR6061T Rear Shock Shafts w/ TiNi Coating and TKR6017T Front Shock Shafts w/ TiNi Coating
TKR5286 Front Suspension Arms and TKR5184 Rear Suspension Arms
TKR5194 Spindle Carriers
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Page 3 Step K-3
Put the screw in upside down so that the head of the screw is in the hex spot that's molded into the spindle. This will aid in clearance in full droop / full steering.
Page 12 Step I-2
Use no less than 4 shims on the steering spindle to limit steering throw. I actually just use one 2mm ball stud washer from my 10th scale stuff since each shim is .5mm.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree13Likes
Old 09-11-2015, 08:48 AM   #301
rcgod's Avatar
Trader Rating: 27 (100%+)
Putting extra washers under the head of the screw doesn't change the setup. And because they give you extra bump steer washers it's easy access if you do want to change the bump steer.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 09-11-2015, 08:55 AM   #302
RokleM's Avatar
Trader Rating: 33 (100%+)
Understood and agree. I was referring to some of the more "creative" solutions I've seen and heard
- Eric G. -
Tekno EB48.4, NB48.4, ET48.3, NT48.3, EB410
Sponsored by: TeknoRC, REDS Racing USA, Pro-Line Racing, Agency-Z, Krawl Off-Road
RokleM is offline   Reply With Quote
Old 09-11-2015, 12:09 PM   #303
Tech Legend
Cain's Avatar
Trader Rating: 240 (100%+)
how things working out for the new car on rough blown out tracks?
< Tekno EB48SL / SCT410.3 | Tekno EB410 x 2 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Cain is online now   Reply With Quote
Old 09-12-2015, 11:28 AM   #304
*Disregard*
Thinking of putting a Buku clutch on my NB48.3. Can someone confirm the Tekno uses a 34mm and has anyone used one on their .3? If so, how did you like it?
Tbyrne1976 is offline   Reply With Quote
Old 09-12-2015, 10:04 PM   #305
Disclaimer: I apologize if this was already covered (I tried searching but did not find)
Is there a full 48.2 to 48.3 upgrade part list available somewhere (i.e., a complete list of the parts I would need to purchase in order for me to upgrade my 48.2 to a 48.3), or better yet, does someone sell a full "kit" with all the parts?
Thanks!
sonk_76 is offline   Reply With Quote
Old 09-12-2015, 10:07 PM   #306
rcgod's Avatar
Thanks!
http://www.fiercercsolutions.com/Tek...kit-FRC010.htm
Dialed RC Hobbies
Old 09-13-2015, 03:32 AM   #307
rcgod's Avatar
If anyone wants to run universals on their buggy, sworkz 92.5mm are a direct fit. They are centered in the outdrives like stock so anything within about 1.5mm should work, like kyosho, mugen etc. Mbx7r front universals are 91.5mm and kyosho are 91mm so either should work.
Dialed RC Hobbies
Old 09-13-2015, 06:02 AM   #308
Thanks for the info. Do you find any advantages of the universal shafts vs. CVA's?
Tampagoalie is online now   Reply With Quote
Old 09-13-2015, 10:12 AM   #309
rcgod's Avatar
I haven't ran them on this buggy yet but I ran kyosho unis on my HB VE8 a few years back and they helped on rough tracks. More forgiving in bumps and no maintenance.
Dialed RC Hobbies
Old 09-13-2015, 08:59 PM   #310
Thanks!
Old 09-14-2015, 05:15 AM   #311
snwchris's Avatar
Here's my list of parts which I bought before the kit was available, but Pete @ Fierce RC Solutions helped get me the parts and get them fast. Also its pretty sweet that he does offer an upgrade package for it.
I did end up finally getting the towers a couple weeks ago
Tekno .2 to .3 Upgrades
TKR6060 X-Long Shock Body
TKR6061 X-Long Shafts
TKR5184 Rear Arms
TKR5199 Rear hubs
TKR5286 Front Arms
TKR5193 Steering Spindle
TKRBB08165 Steering Spindle BRG
TKR1601 Set Screw (Spindle Carrier)
TKR5491 Rear Swaybar
TKR5181 Low CG Wing Mount Set
TKR6159 Pistons 4x1.8
Optional:
TKR5268 Front Tower
TKR5269 Rear Tower
snwchris is offline   Reply With Quote
Old 09-14-2015, 08:00 AM   #312
Default Batteries
What mah batteries do you run in this bug to make it thru a 10min main (1900kv mtr)?
qstorm777 is offline   Reply With Quote
Old 09-14-2015, 08:20 AM   #313
You'd need new inner bearings in the front and rear hub carriers, right? Size 8x19x4?
Old 09-14-2015, 08:34 AM   #314
snwchris's Avatar
I use a 5000mah Lipo and gets me a few warm-up laps based on track size and can get thru 10min Mains. If the track is a bigger 1/8 track then I'll usually do 1 or 2 warm-up laps.
Old 09-14-2015, 08:50 AM   #315
rcgod's Avatar
Same size as the outer hub bearings. Not sure what size those are.
Dialed RC Hobbies
