    Hide Wikipost
Old 03-13-2017, 12:03 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC EB48.3 Thread
Last edit by: MattDub
Welcome to the EB48.3 Wiki
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
Springs:
Low Grip Track:
TKR8772 Yellow Low Frequency Rear Springs and TKR8762 Grey Low Frequency Front Springs
Low to Medium Grip Track:
TKR8773 Orange Low Frequency Rear Springs and TKR8763 Black Low Frequency Front Springs
Medium to High Grip Track:
TKR8774 - Red Low Frequency Rear Springs and TKR8764 - Pink Low Frequency Front Springs
TKR5199B HRC Rear Hubs (L/R, CV or uni, EB/NB/ET/NT48/48.3) - Improves stability of the rear on mid to corner exit. Able to be on power earlier on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6017T (front)
-TKR6061T (rear)
This car is very durable. Here are the spare parts that I recommend you keep on hand:
TKR5020 Hinge Pins (inner, front/rear)
TKR6061T Rear Shock Shafts w/ TiNi Coating and TKR6017T Front Shock Shafts w/ TiNi Coating
TKR5286 Front Suspension Arms and TKR5184 Rear Suspension Arms
TKR5194 Spindle Carriers
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Page 3 Step K-3
Put the screw in upside down so that the head of the screw is in the hex spot that's molded into the spindle. This will aid in clearance in full droop / full steering.
Page 12 Step I-2
Use no less than 4 shims on the steering spindle to limit steering throw. I actually just use one 2mm ball stud washer from my 10th scale stuff since each shim is .5mm.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree13Likes
Old 05-28-2016, 10:19 AM   #1711
Trader Rating: 20 (100%+)
Originally Posted by werner sline View Post
does this 6s power come smoothly enough ?
I believe it comes on smoother than a 1900 4s. But after about 60% throttle it's like turbo kicks in and makes it even faster.
NoobRacer is offline   Reply With Quote
Old 05-28-2016, 11:41 AM   #1712
Originally Posted by NoobRacer View Post
You'll do fine with any of the vehicles you listed at speedrc. It's a smedium (smallish medium) size track that is pretty tight to where you really can't stretch your legs out 100% with ebuggy, so it's more so technical than it is a fast track. The eb48 will do just fine there seeing as how fast it turns.
Would you have any setup recommendations for that track. I have a eb48.3 on the way, but not sure what setup to start with.
proliteandsc is offline   Reply With Quote
Old 05-28-2016, 12:00 PM   #1713
8ight-e's Avatar
Trader Rating: 58 (100%+)
Each motor/setup is different. Very similar top speed and delivery though.. on 6s you should be around 1350-1400kv max. Anything higher makes gearing impossible or just causes too much amp draw reducing the gains from actually running a 6s setup. Unless you are just doing speed passes that is.
Tekno ET48, EB48.2
Durango Fleet - Dex410 v3, Dex210, Desc410, Desc210
8ight-e is offline   Reply With Quote
Old 05-28-2016, 02:37 PM   #1714
justpoet's Avatar
Trader Rating: 16 (100%+)
Originally Posted by RC Matt View Post
http://https://www.3dgydesigns.com/collections/frontpage/products/tekno-diff-shim-kit-1-5mm-and-2-5mm
Is that the arm mod in the second picture in the link? Also what does it do to the buggy's performance?
Yes, that is a version of the arm mod. The point is to prevent dirt and such from building up over time inside the arm/hinge pin area, which keeps the suspension more free and consistent over time with less required maintenance to keep it that way. As long as your suspension is free from reaming vs free from the arm mod, your performance will be the same. It is just easier to do with the cut arm mod.
"We do not act rightly because we have virtue or excellence, but we rather have those because we have acted rightly. We are what we repeatedly do. Excellence, then, is not an act but a habit." -Aristotle
My wallet supports: TeknoRC.com, NorCalHobbies.com, SMC, Sanwa, and several tire/servo companies.
justpoet is offline   Reply With Quote
Old 05-28-2016, 04:30 PM   #1715
Tech Legend
Cain's Avatar
Trader Rating: 240 (100%+)
Do you guys think tekno will eventually make a precut arm?
< Tekno EB48SL / SCT410.3 | Tekno EB410 x 2 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Old 05-28-2016, 04:54 PM   #1716
RC Matt's Avatar
Have any of you guys broke/ripped a battery strap?
Tekno EB48.3
Tekin RX8 Gen 2
Tekin T8 2050kv Gen 2
RC Matt is offline   Reply With Quote
Old 05-28-2016, 05:02 PM   #1717
Tech Legend
Cain's Avatar
I did that on my original EB48.
Old 05-28-2016, 05:07 PM   #1718
Yes
turtle189 is offline   Reply With Quote
Old 05-28-2016, 06:16 PM   #1719
RC Matt's Avatar
Why do you guys think it happens?
Tekno EB48.3
Tekin RX8 Gen 2
Old 05-28-2016, 08:09 PM   #1720
Trader Rating: 17 (100%+)
All the dang time. I have tried various "fixes" but nothing seems to work.
MX304 is offline   Reply With Quote
Old 05-29-2016, 02:39 AM   #1721
werner sline's Avatar
that's what I mean : the kick that actually bothers me a bit about 6s. perfect for pure bashing, but disturbing to put torque on a loose ground. did you change the esc setup ? what about the 20t pinion ?
werner's bunch of RC freestyle: werner's new video : hobao hyper MT trailer 2 : HIGHER!
https://youtu.be/CLPFyAtPCY0
werner sline is offline   Reply With Quote
Old 05-29-2016, 08:18 AM   #1722
Send a message via ICQ to Jan Larsen
I'm using Kyosho MP9E battery straps. Never broken one.
Jan Larsen is offline   Reply With Quote
Old 05-29-2016, 07:07 PM   #1723
Yes, and im guessing chassis flex. I don't have the center brace in and my BIL doesn't either. I don't know if that would help any. We both always snap one of them when we try the 50ft double on my track.. We quit trying that jump and haven't had any issues since.
zemog255 is offline   Reply With Quote
Old 05-29-2016, 07:54 PM   #1724
McKeown's Avatar
Does anyone have a Mamba Monster X esc installed in there buggy? I'm wondering how fitment is?
Thank you
McKeown is offline   Reply With Quote
Old 05-29-2016, 09:50 PM   #1725
I went back into my esc and changed the limiter back to 80 and adjusted my throttle curve on my mt4s. Now she accels smooth as butter. I forgot I ha it set up for my eb48sl that was on 3s.
