    Hide Wikipost
Old 03-13-2017, 12:03 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC EB48.3 Thread
Last edit by: MattDub
Welcome to the EB48.3 Wiki
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
Springs:
Low Grip Track:
TKR8772 Yellow Low Frequency Rear Springs and TKR8762 Grey Low Frequency Front Springs
Low to Medium Grip Track:
TKR8773 Orange Low Frequency Rear Springs and TKR8763 Black Low Frequency Front Springs
Medium to High Grip Track:
TKR8774 - Red Low Frequency Rear Springs and TKR8764 - Pink Low Frequency Front Springs
TKR5199B HRC Rear Hubs (L/R, CV or uni, EB/NB/ET/NT48/48.3) - Improves stability of the rear on mid to corner exit. Able to be on power earlier on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6017T (front)
-TKR6061T (rear)
This car is very durable. Here are the spare parts that I recommend you keep on hand:
TKR5020 Hinge Pins (inner, front/rear)
TKR6061T Rear Shock Shafts w/ TiNi Coating and TKR6017T Front Shock Shafts w/ TiNi Coating
TKR5286 Front Suspension Arms and TKR5184 Rear Suspension Arms
TKR5194 Spindle Carriers
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Page 3 Step K-3
Put the screw in upside down so that the head of the screw is in the hex spot that's molded into the spindle. This will aid in clearance in full droop / full steering.
Page 12 Step I-2
Use no less than 4 shims on the steering spindle to limit steering throw. I actually just use one 2mm ball stud washer from my 10th scale stuff since each shim is .5mm.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree13Likes
Old 04-28-2016, 01:05 PM   #1546
Originally Posted by justpoet View Post
Only thing I can think of to check is to make sure the arms are still straight. I used to get some weirdness like that on the old buggy after a while when the arms would develop a bow to them after a year and a half of heavy racing. I've not seen that with the newer ones though.
A silly thing to check, make sure the hinge pin inserts are the same side to side and one didn't end up rotated while you were doing some other maintenance.
Hmm didn't check the arms I'll look tonight. Hinge pin pills are good I checked. This crazy stuff only happen to me? Lol. The car has been a tank since I got it when they first came out so no complains at all.
Dragonfueled is offline   Reply With Quote
Old 04-28-2016, 05:49 PM   #1547
For those that run 2 2s lipos in series, how are you arranging them?
Calde315 is offline   Reply With Quote
Old 04-28-2016, 06:06 PM   #1548
Trader Rating: 17 (100%+)
Make sure the chassis isn't bent too. If it is twisted, the shock tower would be leaning over to one side making the camber change with equal length links.
MX304 is offline   Reply With Quote
Old 04-28-2016, 07:19 PM   #1549
werner sline's Avatar
this is what I saw on a french forum :
werner's bunch of RC freestyle: werner's new video : hobao hyper MT trailer 2 : HIGHER!
https://youtu.be/CLPFyAtPCY0
werner sline is offline   Reply With Quote
Old 04-29-2016, 09:33 AM   #1550
shannow's Avatar
Honestly avoid it if you can.
I had 2x2s batteries with some foam and stuff to hold it in place but no matter after a short while with crashes and impacts one battery would slide over the over and hit the plugs... this caused the plugs to rip the case off.
After two track session like this I gave up, sold the 2x2s and got the cheap 4s 5000mah 20c from hk for the same price I sold the others and never had any problem since.
Yokomo YZ-2 , sanwa M12
Tekno EB 48.3 1900kv Hobbywing XR8+
Tekno NB48.4 Ko propo servo's Alpha dragon III
shannow is offline   Reply With Quote
Old 04-29-2016, 09:59 AM   #1551
I agree.
Tried 2 2s. and had the cells on one pack dip way below my comfort level. Threw that pack out, and been 4s ever since.
The off-road Tekno 3some-> EB48.4 - ET48.3 - SCT410.3 ---Soon eb410
The oval 3some -> Tekno SCT410.3 - Tekno SCT210.3 - Blitz
Sponsors: Fiercercsolutions.com, AKA, jtbearingco.com, CowRC, Walden Designs, Leadfinger Racing, And BoomRC.net
ezlight is offline   Reply With Quote
Old 05-01-2016, 07:46 AM   #1552
I just built the front shocks, are the springs supposed to be this short? I'd have to have the collars all the way down to get any tension on them
weedsnager is offline   Reply With Quote
Old 05-01-2016, 11:38 AM   #1553
Lowe's48's Avatar
Are those "black rear"??
Tekno Sct410.3-VRP,HW120 SCT-PRO,Pro4-4300kv,Hitec,LRP 8000/2s
Tekno SL.3-VRP,HW120 SCT-PRO,T8i-1950,Hitec,LRP 5000 4s
Weapon of choice : Airtronics M12
Home track : Coyote Hobbies,Ca
Lowe's48 is offline   Reply With Quote
Old 05-01-2016, 11:54 AM   #1554
Front black
Old 05-01-2016, 12:32 PM   #1555
Lowe's48's Avatar
[/U]
Front black
Black,silver and white fronts are 65mm and the rest of the fronts are 70mm.
Old 05-01-2016, 12:35 PM   #1556
justpoet's Avatar
Trader Rating: 16 (100%+)
Yes, it is normal to need to crank down the shock collars for the EB48.3. The shocks are much longer now, but the springs are the same. Using the softer and shorter springs (black, gray, white) will make this even more noticeable.
"We do not act rightly because we have virtue or excellence, but we rather have those because we have acted rightly. We are what we repeatedly do. Excellence, then, is not an act but a habit." -Aristotle
My wallet supports: TeknoRC.com, NorCalHobbies.com, SMC, Sanwa, and several tire/servo companies.
justpoet is offline   Reply With Quote
Old 05-01-2016, 12:46 PM   #1557
Yes, that is normal. Remember, these are truggy length shocks with buggy length springs. With mine at normal ride height I only have 2-3mm of threads showing below the spring collar.
Old 05-01-2016, 06:18 PM   #1558
Hey guys I've got a ?? For you all since all mighty tekin rx8 gen 2 esc decided to die on me at first round off qf on the weekend cost me weekend racing so I had sit watch
So instead buying a other tekin esc what is best fit for a other esc that is in the high range like the tekin that can fit the tekno eb48
coombes is offline   Reply With Quote
Old 05-01-2016, 07:03 PM   #1559
Originally Posted by MX304 View Post
Not really. I usually set my current limited to around 70 which I think you can do without having the Hotwire programmer. Make sure the low volt cutoff is set to 4s, and that you don't have any timing added.
( Tekin 1/8 RX8 Gen2 Brushless System 4030 1900 kv)
Is it already set to 7.4 volts or does it come set to 6 volts ?
Old 05-01-2016, 08:31 PM   #1560
6v
