    Hide Wikipost
Old 03-13-2017, 12:03 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC EB48.3 Thread
Last edit by: MattDub
Welcome to the EB48.3 Wiki
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
Springs:
Low Grip Track:
TKR8772 Yellow Low Frequency Rear Springs and TKR8762 Grey Low Frequency Front Springs
Low to Medium Grip Track:
TKR8773 Orange Low Frequency Rear Springs and TKR8763 Black Low Frequency Front Springs
Medium to High Grip Track:
TKR8774 - Red Low Frequency Rear Springs and TKR8764 - Pink Low Frequency Front Springs
TKR5199B HRC Rear Hubs (L/R, CV or uni, EB/NB/ET/NT48/48.3) - Improves stability of the rear on mid to corner exit. Able to be on power earlier on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6017T (front)
-TKR6061T (rear)
This car is very durable. Here are the spare parts that I recommend you keep on hand:
TKR5020 Hinge Pins (inner, front/rear)
TKR6061T Rear Shock Shafts w/ TiNi Coating and TKR6017T Front Shock Shafts w/ TiNi Coating
TKR5286 Front Suspension Arms and TKR5184 Rear Suspension Arms
TKR5194 Spindle Carriers
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Page 3 Step K-3
Put the screw in upside down so that the head of the screw is in the hex spot that's molded into the spindle. This will aid in clearance in full droop / full steering.
Page 12 Step I-2
Use no less than 4 shims on the steering spindle to limit steering throw. I actually just use one 2mm ball stud washer from my 10th scale stuff since each shim is .5mm.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree13Likes
Old 04-26-2016, 08:32 AM   #1531
Slapjack's Avatar
Trader Rating: 19 (100%+)
I am thinking maybe this can be fixed thru the hotwire settings but I could use a little help. I just finished my new EB48.3 last night. I took my RX8 Gen 2 and motor out of my ET48 and swapped the whole thing right over and bolted it into the EB. When I turned it on the car drives forward when I hit reverse on the controller and it brakes when I pull the trigger. Then it will reverse when I pull the trigger. I tried reversing the throttle in the radio but that didn't work. It was working fine in the ET48 and I didn't disconnect anything. I used the same receiver and everything just swapped it all over to the buggy. Is there a setting in the hotwire that can change this? Do I have to reverse the direction of the motor or something?
Tekno Eb48.3, EB48.2, Tekno ET48, X-Ray XB4'14, '15 & '16, X-Ray XB2 CE, X-Ray T4'15, Hot Bodies D413, Serpent SRX-2, Axial Wraith (full custom Mattzilla Build), Blade 180QXHD
Slapjack is offline   Reply With Quote
Old 04-26-2016, 09:07 AM   #1532
It's been a while since I built mine but is it possible you have the front and rear diffs in backwards?
Tijuana_Taxi is offline   Reply With Quote
Old 04-26-2016, 09:53 AM   #1533
Suspended
What's the best overall diff oil set up to run. Outdoor medium traction dusty dirt
Rc4life1978 is offline   Reply With Quote
Old 04-26-2016, 12:44 PM   #1534
Carter Flotron's Avatar
+1
7-7-5 is pretty common, I've been liking 7-5-5 on a low bite track
Thanks to all my sponsors for 2016!
|Pro-line Racing|Hobbywing North America|Highest Servos|Fierce RC Solutions|
Carter Flotron is offline   Reply With Quote
Old 04-26-2016, 01:36 PM   #1535
Trader Rating: 17 (100%+)
You can reverse the motor rotation in the Hotwire settings but my guess is that you have the diffs in backward in either the buggy or the truggy. Both require the same motor rotation so you should not have to reverse it for one or the other.
MX304 is offline   Reply With Quote
Old 04-26-2016, 01:56 PM   #1536
Also, did you calibrate the ESC?
The off-road Tekno 3some-> EB48.4 - ET48.3 - SCT410.3 ---Soon eb410
The oval 3some -> Tekno SCT410.3 - Tekno SCT210.3 - Blitz
Sponsors: Fiercercsolutions.com, AKA, jtbearingco.com, CowRC, Walden Designs, Leadfinger Racing, And BoomRC.net
ezlight is offline   Reply With Quote
Old 04-27-2016, 08:14 AM   #1537
stanson's Avatar
Hi guys, can anyone help with the stock shock and diffs oils that come with the kit, how do I compare their weight to Associated or Losi oils?
Found a conversion chart but don't know where I am with the stock oils.
Tekno EB48.3 | Xerun 4068 2250kv | Xerun 150A | Hitec 7985MG
Tekno ET48.3 | LRP 2000kv | Xerun XR8 Plus| Hitec 7945TH
Schumacher KAT K1 Aero | Xerun 6.5T 5340KV V10| Toro TS120A Pro | Hitec 8330SH
stanson is offline   Reply With Quote
Old 04-27-2016, 11:19 AM   #1538
From my understanding, the oil in the kits are pretty close to ptrc oil. From what I understand, in the diffs, kit/ptrc feels like 2k less than assoc/losi. Kit 5K feels like assoc 3K.
I haven't heard how the shock oils compare. I would go to ptrcracing.com and look at their conversion chart under the technical data tab.
qstorm777 is offline   Reply With Quote
Old 04-28-2016, 04:54 AM   #1539
Stubbs's Avatar
Trader Rating: 57 (100%+)
Need a little advice from the Tekno crowd. I've been running Tekin RX8 / 1900KV in my various buggies for quite some time, but decided to give the Orion R8.1 Pro a shot to see if it's more durable than the Tekin.
Does anyone on this thread have one mounted in an EB48.3 / ET48.3? The separate capacitor bank, and the rather large switch is a real bugger to mount. I found some pictures online of someone who had one mounted in an SCT410, but the 1/8th motor is too long to mount it that way.
Any pictures y'all have would be greatly appreciated. Thanks....
Mike Stubblefield - www.capefearraceway.com
"If you're not racing to have fun, then you're doing it WRONG."
"All you need is WD-40 and Duct Tape. If it moves, and it shouldn't, use the Duct Tape. If it doesn't move, and it should, use the WD-40."
Stubbs is offline   Reply With Quote
Old 04-28-2016, 05:02 AM   #1540
Any idea why one of my front camber links would have to be shorter then the other side to get the same camber. I've checked everything I can think of but the right side has to be about 2-3 mm shorter. If I run a full short link it bottoms out in the link ends at 0 degrees while the other side I can run to -3. Going nuts lol
Dragonfueled is offline   Reply With Quote
Old 04-28-2016, 05:13 AM   #1541
did you mix up a camber link and a steering link when building?
TEKNO SCT410.3; Hobbywing Sct-pro; Hobbywing 3656 4000kv; Protek 130S; SPC 70C 7200mAh 2s
TEKNO EB48.3; Hobbywing Xerun 150a; SMC 1900kv; Savox 2274SG; ECO Power 35c 4100mAh 4s
Associated B5R; Trackstar 120a turbo; Trackstar 8.5t; Solar D771; Reedy 65C 5800mAh 2s square
kyleman7 is offline   Reply With Quote
Old 04-28-2016, 05:20 AM   #1542
jmcelroy42's Avatar
Also check to make sure that both rod ends on the link are threaded on evenly. If one is a couple turns out from the other you might not be able to make it as short as you need.
EB48.4 - TEKIN RX8 & SMC 2100
EB410 - TEKIN RSX & ORCA 5.5
RC10B6 - HW Justock & 24K 17.5
jmcelroy42 is offline   Reply With Quote
Old 04-28-2016, 05:35 AM   #1543
Nah this is a well used buggy that just had this issue pop up . Threads are equal, and they are both actual camber links not toe links I removed the ends and checked.
The actual gap is smaller on one side and still doesn't have enough negative camber. In other words I have more negative camber on one side even though the gap is bigger between the links. Weird
Old 04-28-2016, 12:17 PM   #1544
justpoet's Avatar
Trader Rating: 16 (100%+)
Only thing I can think of to check is to make sure the arms are still straight. I used to get some weirdness like that on the old buggy after a while when the arms would develop a bow to them after a year and a half of heavy racing. I've not seen that with the newer ones though.
A silly thing to check, make sure the hinge pin inserts are the same side to side and one didn't end up rotated while you were doing some other maintenance.
"We do not act rightly because we have virtue or excellence, but we rather have those because we have acted rightly. We are what we repeatedly do. Excellence, then, is not an act but a habit." -Aristotle
My wallet supports: TeknoRC.com, NorCalHobbies.com, SMC, Sanwa, and several tire/servo companies.
justpoet is offline   Reply With Quote
Old 04-28-2016, 12:39 PM   #1545
Deleted
