Old 10-24-2005, 01:53 PM   #16
CDG
CDG's Avatar
Send a message via MSN to CDG Send a message via Yahoo to CDG
Originally Posted by o.s. power
yes, that screw that sits below the spur is the only one you cannot put a nut on. Your best bet is to leave that screw the same length that it is now. Just put nuts on all of the rest, make sure you use loctite too, but not too much.
I have found that locktight is a oneway trip on plastic, it goes in once and destroys the plastic if you ever have to remove the srew, is there a particular type of locktight for plastic? I currently only have MIP Thread Lock in a little white tube??? and I'm sure its only for the metal parts?
CDG is offline   Reply With Quote
Old 10-24-2005, 02:43 PM   #17
Trader Rating: 14 (100%+)
just put the loctite on the nut and then thread it on the screw.
o.s. power is offline   Reply With Quote
Old 10-24-2005, 04:16 PM   #18
J_Bone's Avatar
You are correct. loctite will break down the plastic. Use shoe-goo or silicone(RTV).
J_Bone is offline   Reply With Quote
Old 10-24-2005, 11:20 PM   #19
CDG
CDG's Avatar
for plastic areas with some material left in then I usually shave off a little bit of plastic from a hot glue stick and stick it in the hole, that works most of the time. I make a peice like a toothpick, and put it through, then tighten the screw ever so lightly, it holds the screw in every time, unless I hit a curb , then its usually time for a new component .
FS/kanai 2/rc10gt arr/mugen mst-1 w/parts/rc10gt roller mint/recievers/servos thedoc329 R/C Items: For Sale/Trade 9 02-02-2008 04:09 AM
TiR Pinion Gear Clearance Nexus Racing Georgia Racing 0 05-22-2007 06:56 PM
Rc10GT loaded with titantium, OS, Futaba gear $210 shipped Weez R/C Items: For Sale/Trade 11 12-27-2006 01:54 AM
RC10GT gear ratios Modified_Racer Monster Trucks 1 11-25-2005 10:10 PM
tc3, rc10gt, losi, assoc, 48p and 64p pinion gear sets, orion rev motor islandRC R/C Items: For Sale/Trade 19 04-06-2005 01:01 PM
