shorty lipo power output vs full size, same mah .... >
Old 06-02-2015, 07:02 PM
hacker's Avatar
Trader Rating: 141 (100%+)
Default shorty lipo power output vs full size, same mah ....
If you had the same brand lipo, with roughly the same capacity, will a full size pack have more punch compared to a shorty?
hacker is offline
Old 06-02-2015, 07:03 PM
Hoese37's Avatar
It shouldn't, unless the C rate is very different.
Hoese37 is offline
Old 06-02-2015, 07:53 PM
8ight-e's Avatar
Trader Rating: 58 (100%+)
Typically density of equal packs in quality would dictate you see reduced C rating to achieve the similar mAH. I would be very surprised if it didn't change some unless the two packs are of different quality, chemistry & material changes from improvements over the years.
A full size pack would be say your typical 5400 60c, the shorty would end up being a 5400 40c, this may still be enough to handle your given load but in theory the the 5400 pack at 60c would allow 324amps, while the shorty at 40c would be 216amps. I suspect both would be plenty for 1/10 or 1/8 ebuggy.. maybe signs of softness at the end of the pack most noticeable as you move up in load.
8ight-e is offline
Old 06-02-2015, 08:16 PM
I don't think it's a very realistic question. Same brand / similar packs of different sizes are very likely to have different capacities.
In general a full size pack with have slightly better electrical performance, but weighs more too which can bog down the RC performance. Practically it probably depends on the vehicle, can it get close to minimum weight with good balance with a full size pack? Assuming stock classes.
Dave H is offline
Old 06-02-2015, 08:46 PM
hacker's Avatar
My rear mount serpent with shorty is about 25grams underweight. So yeh just trying out different configurations. I personally think a full pack will have a higher voltage output given the lipos are the same C rating and mah. I just think getting with a smaller physical size of a shorty, you would have to be 'giving' something up.
hacker is offline
Old 06-02-2015, 09:21 PM
Hoese37's Avatar
You are, weight. As lipo technology advances, youre going to get the same battery, just in a smaller package. Its the same as everything else in the electronics world.
Hoese37 is offline
Old 06-02-2015, 10:11 PM
8ight-e's Avatar
Please give just one example where the same product line has the same C rating and carries the same mAH in both a standard pack and a shorty pack. The only way this would ever happen is if you are talking about pretty low mAH packs 5k range.. none of the standard 6500-7200mAH packs fit. And at the same lower mAH those packs are going to be nearly equal in weight, so weight is not what you are gaining other than a couple oz of plastic housing,,, maybe.
8ight-e is offline
Old 06-03-2015, 06:46 AM
Hoese37's Avatar
Ever notice from years ago when a 3800 lipo was considered a big Mah? Now we have batteries hat are more than double that capacity in the same physical size.
Hoese37 is offline
Old 06-03-2015, 07:00 AM
VooDooPH's Avatar
Trader Rating: 18 (100%+)
i have never seen a shorty go over 5000mah...
VooDooPH is offline
Old 06-03-2015, 07:33 AM
Suspended
Yet. Just as it was pointed out earlier, as the technology is refined, the capacity of shorty packs are going to go up. Obviously full size stick packs are going to increase in capacity too,
Capacity isn't really the point of a shorty. The decrease in weight (which is significant in 2/4wd 1/10th scale buggy) as well as the decreased moment of inertia are the main advantages of shorty packs. Different types of vehicles have different needs, and shorty packs fill the roll better than stick packs for 1/10th buggies.
Ultimately, if the capacity and C rating are the same the packs will perform the same, regardless of size.
Oh, one last thing. The first Orion lipo was 3800mah and 30C, the first shorty was 3800mah and 60C.
Mantis Toboggan is offline
Old 06-03-2015, 03:15 PM
Orion offered several car lipo packs before the 3800mAh 30C. Including the 4800mAh Platinum pack. Which is a better comparison to current packs, as it had the now familiar nearly squared off shape.
The also earlier 3200/3600 and even the 3400/3800 were considerably smaller with a more rounded shape. And thinner with the cell bumps to better fit some of the roundy cell chassis of the day. (Wild guess on my part, perhaps also to reduce costs to help gain acceptance of the new hard case package, the Platinum was fairly expensive IIRC)
Even going back nearly a decade, early and comparable full size lipo packs had as much or more capacity/mAh as most any current shorty I've seen. C ratings have certainly went up a bit though.
Dave H is offline
Old 06-03-2015, 03:53 PM
Suspended
Trader Rating: 61 (100%+)
What IR? What temp?
Socket is offline
Old 06-03-2015, 07:12 PM
8ight-e's Avatar
Actually I've been running electric and brushless since the early days.. 5000mah packs have been around just about as long. You're talking nimh packs with 3800 :P and BTW physical size yes,, not weight. I agree chemistry is improving, density is improving but those packs in the 6500-7200 range are much heavier... it's always a balance
8ight-e is offline
Old 06-03-2015, 10:17 PM
hacker's Avatar
not really, the 7000mah batteries are way thicker
hacker is offline
Old 06-04-2015, 08:55 AM
Hoese37's Avatar
Not sure which 7000 youre looking at, but here batteries need to meet ROAR approval, which is just the physical dimensions.
Hoese37 is offline
