Tire break in?
Tire break in?
Hello all!
Was out at OCRC two Fridays ago and realized that even though I was running tires/foams in clay compound, my tires were not as soft and sticky as everybody else. What are people doing in order to get this level of traction? I'm waay off the level of perfomance that these guys have, granted some of it is setup, but alot of it is surely tires, advise?
Thanks all!
Thanks all!
Most likely using a traction additive. WD40, Liquid Wrench (blue label) and PB Blaster are effective and inexpensive (esp. LW) but the track may have rules about what can/can't be used so it's best to ask. Lots of guys like Sticky Kicks too.
Are you sure, everyone else is on clay compound. Some might be running the same tire but in soft compound, instead of clay. Before you start applying different chemicals, like liquid wrench, wd40 etc. Check with the track and ask them if it's allowed and what do they suggest for sauce.
Whats the process of application to the tires? Do I need to apply and let soak or something like that? I've also heard of Simple Green.
does traction compound make tires actually sticky or just more soft?
what is "aced"?
Ive also heard the concept of "breaking in" tires. How is this accomplished other than simply running a tire?
Cool! I get to run in the street like the good ol days! lol
