electrix ruckus with Tacon 3660 4000kv motor
motor
96m210-3660-4000kv-6t
http://www.hobbypartz.com/96m210-3660-4000kv-6t.html
esc
HobbyWing eZRun-60A-SL
http://www.hobbypartz.com/ezrun-60a-...-1-10-car.html
pinion
32p 12t 5mm shaft
http://www3.towerhobbies.com/cgi-bin...?&I=LXBAWC&P=7
spur
Traxxas Spur Gear 32P 64T Nitro Hawk
http://www3.towerhobbies.com/cgi-bin...?&I=LXJE12&P=7
waiting on steel driveshafts
Integy XHD Steel Rear Univeral Drive Shaft
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXDJKE
have the tranny metal gears,
http://www.walmart.com/ip/Metal-Gear...ctrix/37292350
with 6-7c nimh 3000 packs it runs great, tears around the yard does not pull wheelees
with a 2s 6000ma 60c lipo it broke several of the traxxas upgraded drive shafts yokes ect..
pulling wheelees at 40+mph
im thinkin the motor is for 1/8 scale or nitro conversion, its way more power than a 1/10 car can use
cant gear the ruckus down much farther, 10-11t 32p 5mm gears are tough to find
esc
pinion
32p 12t 5mm shaft
spur
pic of broken parts
left: electrix stub axle (twisted)
right: traxxas stub axle (broke pin)
bottom: nylon traxxas diff yoke (shattered)
update
swapped out the traxxas u-joint parts for axial steel u-joints
http://www3.towerhobbies.com/cgi-bin...?&I=LXSAP6&P=7
put the 8mm ball from traxxas heavy duty stampede axials in them
(pressed out 2mm pin, 3mm pin slides out, pressed out 2.5mm pin from traxxas ball)
(yoke has 6mm gap /w 3mm pin hole, but 2.5mm pin works fine they are hardened steel)
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXAVNN
(pressed in 2.5mm pin thru traxxas ball and axial yoke)
so far its working good
esc is up to #3 with no new broken parts yet
driveline setup is holding up well
http://s1.postimg.org/i3eu6l67z/20150517_211125.jpg
need a wheelie bar
http://s3.postimg.org/qcii7w2pf/20150530_045556.jpg
need a wheelie bar
