Problem building CVA
I for the life of me can't get the pins back through the cva axle to put the cva back together on my sc10. I stripped everything down yesterday and hit it with brake cleaner. Now I can't get the pin through either hole, with either pin on either axle. WTF. This is frustrating I'm not sure why this won't work, also tried a solid axle pin, and nope.
The one that keys into the wheel is a press fit and takes some effort.
Tried new pins, got pissed and used some pliers. Almost got the pin all the way in, but couldn't get it through the second hole in the axle. Now I'm having fun trying to remove the pin. I've never had an issue like this. Can I buy just more pins, instead of an entire rebuild kit?
It's not the set screw, it's totally removed. The problem is pushing it through the axle part not the inner capture part that holds the dogbone. Having it completely disassembled just the pin and the axle, I can't get the pin through.
