Tekno RC SCT410.3 Thread
#5581
I converted mine to nitro for awhile and it was a blast! If there was a race class for it I would of kept it that way.... 2s is rough on electronics and nitro racing sct is awesome. It's a quick swap, try it out if you have both kits.
#5583
When I built this truck, all the diffs seemed to move pretty smooth. Still do individually. With the car on a stand running the motor very slowly, I occasionally get a little pop and see the center drive shaft flinch a little. Is this just a product of three diffs running slow with no resistance? Anyone else experienced this? At higher speed, it's inperceptable.
The reason I even noticed was that my rear out drive is nearly touching the receiver case where it has a buldge to accept a screw. I was running it slow to see if it made contact. I plan to take a Dremel to that part of case to give it a hair more clearence, as I think it has made contact.
#5585
WonTonsChicken is talking about a worn spot in the outdrive, I believe. Check the outdrives to see if they have excessive wear to the slot, causing the outdrive to catch and not move as smooth as it should.
#5588
That's kind of what I was picturing .You guys are a huge help. Thanks. I'll be able have a look after this weekend and I'll let you know what I find . Again, thanks.
#5589
While building all of the turnbuckles, I noticed the all of the pivot balls binds in the ball cup, I had to grind down each and every ball to have it moving freely. Is this normal? I have built a few other kits before, and have never seen this.
#5590
I wouldn't have ground them down...if they are a little tight you just take some pliers to the ball cup. By pinching the ball cup slightly you "stretch" the plastic a bit allowing the ball to move freely. I am pretty sure their is a video Lutz put out that explains this. I will see if I can find it for you.
#5592
Thanks guys for the useful tips!!!!!
#5593
Well, no cupping found anywhere. After more thought, I think it's probably nothing. The speed I'm getting the clunk on the test stand is super slow. May even be some kind of low speed cog or something with pinion backlash. Running it wheels on the ground at very low speed there's nothing, and without the motor engaged everything moves very free as well .
On a side note, my issue of the rear out drive being too close to my receiver case, I found the set screw lose, so it backed out a little.
#5594
First off, really appreciate all the info on here. Got the bug a while back getting a Slash for my kid and I to mess around with. Took it to the track a number of times and then decided I wanted to build something. Went with the 410.3. Fast forward to first track day, and my RX8 suffered an unfortunate event due my own negligence of only using double sided tape to secure it. Broke lose and lost a post in the process.
Now I'm looking to replace it with a HW Xerun XR8 SCT pro. Will this ESC be ok with my Tekin 4300HD motor? It seems to me it would be just fine, but thought I'd double check here.
Thanks.
Thanks.
#5595
Finally got my short bus last night. I am usually a TLR guy but this truck seems to be bullet proof and had so many advantages over the SCTE. I won't be building it for at least another week or two but had already seen all of the helpful info that you guys put up here and I thank you for that in advance! Here is to a new RC adventure to me lol
