Tekno RC SCT410.3 Thread
#5656
Hey all,
Is there a Tekno branded clamping aluminum servo horn for Hitec servos for the SCT? I went on Amain and didn't see one - I believe they have a 24T spline, correct? I only saw 23 and 25T in Tekno brand. Or a good one from another brand - I see a Hitec specific one from M2C that's not clamping.
#5657
Hey all,
All of our 23T and 24T servo horns have been discontinued . The standard is 25T and that is the only spline we will be manufacturing in the future.
#5658
Hey all,
#5659
bummer! My servo is the popular Hitec HS-7955TG but it looks like 24T spline. Anyone know of alternatives?
#5660
#5661
One of these days, I need to 100% read through this thread.
I run on a indoor clay track.
My sct410.3 started out at 7 lbs.
Got it down to 6.5 lbs.
Next change I'm thinking about, is the motor.
In the past, I ran a Tekin 540 size motor, the 4300. I am currently running the Maclan 540 size motor, their 4150.
Both are stupid fast for our tack.
I'm running the Hobbywing XERUN speed control, as I could not find the older Orion one I liked.
If I go down to a smaller size motor, to save weight. Would a Hobbywing XERUN SCT motor be a good one? 5100? 4300? 6100?
Or another make? How do the KV's compare between the smaller and larger Cans?
#5662
I just got this SCT with the smaller can HW 4300 and it rips. The KV should be the same for either size can. I think it balances the car out better too. The guy that owns my local shop that runs on a small high grip clay indoor track says the 3800kv is the sweet spot since they are so fast. I get that totally But I ended up going for more power.
#5663
#5664
Where is there a tiken 4700? I just see a 4600. Link?
#5666
#5668
So to save some weight, I went with a "Hobbywing XERUN SCT 3652SD G2 Sensored Brushless Motor (4300kV)".
It has a smaller can, and lighter than my:
"Maclan MR4 Competition 4-Pole SCT Sensored Brushless Motor (4150Kv)"
and I used to run a:
"Tekin Pro4 HD 4-Pole Brushless 550 Motor w/5mm Shaft (4,300kV)"
Overall, I believe the Mclan is smoother and runs cooler. But in overall power on an indoor clay track, all 3 are stupid fast. I'm sticking with the Hobbywing, as it is lighter, and more room to run wires. There would be no way, I would feel the need to purchase a motor with more power. I would not even hesitate to take all 3 of these, to a big outdoor track.
#5670
are there any base set-ups for med ,hard pack,and PROGRESSIVE BANKING ?
