Tekno RC SCT410.3 Thread >
Like Tree166Likes
    Hide Wikipost
Old 10-10-2017, 01:54 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Tekno RC SCT410.3 Thread
Last edit by: DirkW
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8702 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Old 02-14-2018, 06:45 AM
  #5431
Originally Posted by shadaloo View Post
I was using Impacts and Subcultures when I tried the setup, I just got my first set of Cityblocks for sct in the mail 2 days ago.. I will give it a shot with those tires and see how it is. I really want to get that setup to work, since pretty sure every setup sheet for sct uses 15/15/10.... but so far 7/7/5 or 5/5/5 has been superior. I will give it a shot with cityblocks this weekend and see how it goes!
I use that setup with 7-7-5, and works for my driving.
Jordan Anderson and shadaloo like this.
ezlight is offline
Old 02-14-2018, 09:29 AM
  #5432
shadaloo's Avatar
Originally Posted by crash n go View Post
Are you using the standard rack or the 48.4 rack?
48.4 rack, I also tried it before the .4 rack came out and had no luck.... I'm not sure if its better indoors, but at my track it was awful compared to 7/7/5 or 5/5/5. Anyone else from Florida try 15/15/10?
shadaloo is offline
Old 02-15-2018, 04:14 PM
  #5433
Hey guys- I recently bought my first Tekno car, the EB410. I'm so impressed by Tekno, I wanted to get rid of my TLR SCT and replace it with the SCT410.3. I heard this thing is a tank and wanted price it out. What are the MUST have upgrades if any? I also noticed its on sale on most sites. Are they making a new SCT? Thanks
lim202 is offline
Old 02-15-2018, 04:24 PM
  #5434
thirtydaZe's Avatar
the wiki pretty much sums it up.
thirtydaZe is offline
Old 02-17-2018, 02:19 PM
  #5435
It is probably here, but I'm lost. What wheels are good? Indoor clay? Ones that will not hit, and will hold up?
sea1swk is offline
Old 02-17-2018, 10:32 PM
  #5436
justpoet's Avatar
Trader Rating: 16 (100%+)
The AL "A block" (front most hinge pin holder) and what every Tekno needs, an AL servo horn. Several other upgrades are nice, but not required for most people.
justpoet is offline
Old 02-17-2018, 10:41 PM
  #5437
justpoet's Avatar
Many wheels work, you can find much of the info in the wiki at the start of this thread. Probably the best ones are the DE Speedline wheels, as they're made for the heavier vehicles like today's 4wd SCs. The best tires to put on that for indoor clay will vary depending on the clay. Ask the fast folks that are running there what they're using, and use the same thing.
justpoet is offline
Old 02-18-2018, 05:55 AM
  #5438
B3nno810's Avatar
If its anything like the buggy. You will want to ditch the shock cap bushes and use fuel tube. Alloy servo horn. Delrin shock guides and the extended spring perches. You will want to replace the plastic hinge pin carriers (abcd blocks) with the alloy blocks. From memory the tekno sct has issues with the front hubs because of the steer stop screw set up. So be careful of that.
B3nno810 is offline
Old 02-19-2018, 07:27 AM
  #5439
JoeRC123's Avatar
Shock cap bushes? Bushings? Fuel tubing for bushings? Please elaborate. I'm interested.
JoeRC123 is offline
Old 02-19-2018, 05:05 PM
  #5440
B3nno810's Avatar
The upper shock cap bushings are horrible. Theyre too hard, and they constanly flog the caps out (they do on the buggy because of the metal caps). Even with the m2c bushes (delrin), the caps flog. Caps must be too soft also. You use fuel tube as the cap insert. It allows smooth shock movement and doesnt cause the shock caps to flog out. You cut a small section to fit the stand off, fit the shock onto it and then fit your nut. Dont over tension as you will cause binding. Works a treat. After changing about 6 sets of shock caps in a short period of time, i went to fuel tube and didnt need to change another set. Alot of people do it. Alot cheaper than buying shock bushes also.
B3nno810 is offline
Old 02-19-2018, 08:22 PM
  #5441
Thanks guys!
lim202 is offline
Old 02-20-2018, 05:27 AM
  #5442
celt's Avatar
Thanks guys!
Sometimes my job requires I step out of the hobby for a few months and up to a year.
Two things I never part with: my tools and my Tekno's. Build your SCT410 and you'll remember this post.
celt is online now
Old 02-20-2018, 07:01 AM
  #5443
JoeRC123's Avatar
What exact fuel tubing type and size? This issue is happening to me now. I'd rather use something that lasts. My shock bushings are really sloppy right now.
JoeRC123 is offline
Old 02-20-2018, 04:35 PM
  #5444
B3nno810's Avatar
I use dubro tubing. Worked a treat. You will never go back to the Tekno bushes or m2c after doing it.
B3nno810 is offline
Old 02-20-2018, 05:35 PM
  #5445
a1
whats the recommended battery ? I got a a smc 90c 2s that crapped out after a couple months, want to try something else. Running a 4000Kv motor
a1 is offline
