Tekno RC SCT410.3 Thread
#5118
Thanks for the info and I see the pills charts on the bottom.
I guess my question is more so to get a better understanding of how the angle of the pin possibly affects things.
So for example, I have the zero antisquat setting up front, but the max high pill setting in the rear giving that downward sloping angle going Rear to Front. I am assuming Roll Center, etc.
Something like this kind of chart is what I am thinking:
https://www.teamassociated.com/pdf/c...Pill-Chart.pdf
Thanks for your help!
#5120
http://www.teknorc.com/wp-content/up...oor%20Dirt.pdf
I think this will get you pretty dialed, its a great setup with minimal changes needed.
#5121
For a good starting point I would start here
#5123
Diff shims are a case by case need. I've ran none, 1 on either side, 1 on both sides, and 2 on one side. There is no simple answer to that question. Just when the mesh feels good, and there is no loose/binding with side to side pressure.
#5124
Tech Legend
reason I am asking is I noticed something odd last race that had me wondering, some more "metal" noise when driving. I don't notice anything handling wise, feels fine there. But just a more loud vehicle.
And mind you, the vehicle was rebuilt with any questionable bearing replaced with fresh hardware, and fresh diff fluid all around. At the track though I noticed the rear felt tight, so I removed the one shim I had meshwise.
#5125
#5127
Hey guys, just wanted to let you know that I ran my SCT410.3 this weekend with this setup and it was amazing. Best I've ever felt while driving an SCT. It requires option parts, but it's a great investment if you're an avid SCT racer.
#5128
Glad your finally happy with it bud.
