Question About kV
Old 03-10-2015, 08:46 PM
OutKasted's Avatar
Default Question About kV
Does higher kV automatically give more top end at the sacrifice of torque? I
I'm going to be running a 2S setup in a converted 1/8 buggy to SC and a 1/8 buggy. Both of these vehicles carry a lot of weight (8lbs) and I am looking for the best balance of speed and torque. I want to be able to clear the jumps on an indoor clay tracks, but not get outran down the straight, by everyone (17.5 buggies run with me down straights; currently running 4500kV).
Should I go up or down in kV?
OutKasted is offline
Old 03-10-2015, 08:55 PM
1/4milecrazy's Avatar
WHat motor are you running right now? I run a Castle SCT Pro 2400Kv on 2s in my DESC410 and there is no way a 17.5 buggy can hang with me on the straight.
Does your motor make enough torque to accelerate the weight? It sounds to me as there is something very wrong with your combination. 1/8 buggy on 2s seems to me like a tough thing to do without spending a bunch of coin.
1/4milecrazy is offline
Old 03-10-2015, 09:16 PM
OutKasted's Avatar
Currently running Viper Copperhead-R combo (sensorless 4 pole system). Motor is 4500kV. That is why I'm asking the question. I believe that I need a motor that has more torque to carry the weight, but should I increase or decrease kV to get it, there are lots of 4 pole motor options. You say you're running 2400kV on 2S? Really? That gives the correct RPM to get good speed?
Old 03-11-2015, 07:22 AM
Trader Rating: 15 (100%+)
What gearing are you running. What is your Motor/ESC temps?
masher81 is offline
Old 03-11-2015, 09:40 AM
OutKasted's Avatar
Currently running 46/16 (mod1). Tried various combinations of spur and pinion. Current temps are at 160 (motor), 100 (ESC), and 105 (battery) with a full pack run (6500mah 65c).
Old 03-11-2015, 09:59 AM
skeasor's Avatar
Higher KV will produce more RPM's and less torque
Lower KV will produce less RPM's but more torque.
But a lot other factors come into play though...like gearing.
skeasor is offline
Old 03-11-2015, 10:54 AM
eXXon's Avatar
Size of the can is important, as is the wattage of said can (motor).
For 1/8th scale, recommend you get a can with at least 40mm Diameter and 68mm length.
Lower KV is used for heavier RCs, has more torque, can be geared up to be a speed demon, but needs higher input voltages to achieve high RPM.
Higher KV is for lighter RCs and doesn't require high voltages to achieve high RPM. But if used in a heavy RC, then chances are you'll get dusted down the straights from a lower KV motor geared properly.
eXXon is offline
Old 03-11-2015, 11:31 AM
OutKasted's Avatar
Ok...so as a general, wide sweeping, rule, the heavier the vehicle the lower kV you should run so as to have more torque than horsepower?
Old 03-11-2015, 11:42 AM
OutKasted's Avatar
I can run this as a 2s application and still get good rpm? Or will I have to gear it way up to run with other 4x4 SC?
Ok, this makes sense...thanks!
Old 03-11-2015, 06:07 PM
rcjunky1's Avatar
You want a high kv 4 pole 550 motor. What you have shouldn't be slow though, should be fast as a mod buggy
rcjunky1 is offline
