Need help with Avid Evo triad 1020 mod kit for sc 10.2 >
Old 03-10-2015, 06:12 PM
Trader Rating: 14 (100%+)
Default Need help with Avid Evo triad 1020 mod kit for sc 10.2
I am putting on an avid evo triad 1020 mod slipper on my sc10.2. In the directions they don't tell you where to use the cone washers? Do I need to put these cone washers on? Also, what is the correct adapter for the sc10.2 that you put on just before the nut? Any info would be greatly appreciated.
Blues Hockey is offline
Old 03-10-2015, 10:07 PM
Trader Rating: 19 (100%+)
Here are the instructions for the Schelle Nova slipper assembly which is identical to the Avid Triad kit.
Basically, install one slipper pad into the spur. Install one drive plate with the cutout facing up. Install slipper pad two. Install flat washer, cone washer, flat washer combo onto input shaft. Install second drive plate with cutout facing down.
The flat washer, cone washer, flat washer is sandwiched between the two drive plates nestled inside the cutouts.
Fixmy59bug is offline
Old 03-10-2015, 10:09 PM
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 167 (100%+)
Actually the evo triad doesn't utilize the cone washers. Try here:
http://www.avidrc.com/downloads/Tria...structions.pdf
Matt Trimmings is offline
Old 03-10-2015, 11:40 PM
Wow...
That's new.
However, following your link, there is a ** at the bottom of the first page stating use of the centering washers is optional. And if desired, should be installed as I outlined earlier.
