2s lipo problems
Old 03-07-2015, 05:58 PM
Default 2s lipo problems
i was driving my slash 4x4 with the castle sct 3800 combo and a bias 2s 25c 5000 and i jumped a snow bank and the battery literally just stopped working. still showing 3.7 in each cell. i used another battery to make sure it wasn't the esc its the battery. it wo.t connect to the charger but i can connect to lvm and reads7.4 all and 3.7/3.7 idk what happened some help would be great.
slash4x4sct91 is offline
Old 03-07-2015, 06:13 PM
bash bros's Avatar
Sounds like you just hit the low voltage cutoff.
Does it charge if you hook it up to the charger?
bash bros is offline
Old 03-07-2015, 06:35 PM
Trader Rating: 235 (100%+)
7.4 is not low voltage. Should be able to go down to 6.6 without issues unless cutoff is set higher. Sounds like the connection in the battery case or connector may have broke loose.
Check battery connector/wire.
Andy Koback is offline
Old 03-07-2015, 06:52 PM
will not charge and wont do anything.idk whats going on. wires seem tight in there nothings loose.
Old 03-07-2015, 07:21 PM
harry697's Avatar
Trader Rating: 118 (100%+)
Sounds like a bad connection inside the pack. I had a 4S pack do that before. After a somewhat hard flat landing, it shut down. Charger wouldn't recognize the pack and it wouldn't power the esc, but all four cells would read on a stand alone balancer. Never did figure it out, but the only thing that made sense was a bad connection between cells inside the pack.
harry697 is offline
Old 03-11-2015, 06:58 AM
lbenton's Avatar
Trader Rating: 48 (100%+)
what kind of plug is on it? Deans / Traxxas?
I would try to replace the plug to see what happens. The Balance lead is what is used to measure voltage, but they main plug is what feeds everything. Even if you voltage test at the plug you can still have a case where it is not making good contact with the male plug on the ESC or charger.
I ran into a lot of this once when I thought could save some $$ on knock off deans plugs.
lbenton is offline
