Old 10-09-2005, 03:46 PM   #1
R1 Uffe's Avatar
Default Big Bearing to the V-Spec
Hi !!!
Im "calling" from a little country named Sweden now, im trying to find out what size it is on the big bearing in the V-Spec. My friends are not shur if it is 25mm or 25.4mm. Can you help me on this.
And now, were do i buy this bearing????
I know one page, and it is www.vxb.com, do you have a better page i can look at ???
Ulf from sweden
R1 Uffe is offline   Reply With Quote
Old 10-09-2005, 08:14 PM   #2
Trader Rating: 14 (100%+)
the big bearing, known as the rear, is 25.4 mm.
I take it your bearing failed on you too? Alot of us over hear have had that problem too. Make sure your piston/sleeve are still in good condition.
check out boca bearings, these guys make some of the best bearings around.
here is the link - vz-b bearings
o.s. power is offline   Reply With Quote
Old 10-10-2005, 12:07 AM   #3
R1 Uffe's Avatar
thx OS Power for the answer, my bearing has not faild yet, im trying to get a new bearing if its fail´s. Over here you buy a new bearing for 55$ and in USA you buy it for more then the half price.
I found a bocabearing here to, do you know anything about the "store"
http://www.amainhobbies.com/product_...46b53d5f9b3d81
Do you know anything about vxb.com http://www.vxb.com/page/bearings/CTGY/14mm
Thx again for everything
Sweden
Old 10-10-2005, 12:52 AM   #4
When I had the OS VZB The rear bearing use to fail. I replaced them with the Novarossi one then never had a problem after that. The bearing is the 25.4mm
Tamiya 416x Drifter
Venom Creeper
DJI Phantom
Futaba Radio's
chrispy is offline   Reply With Quote
Old 10-10-2005, 01:13 AM   #5
R1 Uffe's Avatar
I have heard that to about Novarossi bearing.
A little OT here, if i want a new piston and cylinder to my V-Spec, do you people over there have any good and cheap web site i can check out
Old 10-10-2005, 01:23 AM   #6
Piston and Sleeve use to cost me about $180 - $200 Aus which is about half price of the motor. But that was a couple of years ago.
Tamiya 416x Drifter
Venom Creeper
DJI Phantom
Futaba Radio's
Old 10-10-2005, 09:50 AM   #7
amainhobbies from what i heard is a good company to do business with.
Old 10-10-2005, 08:45 PM   #8
SpeedBump57's Avatar
Kendall Bennett from A Main Hobbies is great to deal with. He has a great store and is very willing to help. Kendall is also a racer.
SpeedBump57 is offline   Reply With Quote
Old 10-10-2005, 10:00 PM   #9
Suspended
Send a message via MSN to rinkeberg
hej D1uffe hur e de me 1/8th off road, gar du till furelund off road banan? jag bara vill veta om ni comer at ha nagra competitions nesta aret Oct-Nov. ferlat om min svensk e daligt, jag har inte varit e Malmo 8 ar och casterracing behover nagon e sweden som can vara distributor, om du eller nagaon som har bra experience me 1/8th offroad vill sa can du ga till Casterracing.com och skriva pa engelska till head office.
rinkeberg is offline   Reply With Quote
Old 10-11-2005, 12:58 AM   #10
R1 Uffe's Avatar
Im not coming to Furulund, im living in the north of sweden, its to far to drive. We hav plenty of hobby dealer here in Sweden, you can ask them, 90% of the Hobby dealer is coming to Furulund
Old 10-11-2005, 01:13 AM   #11
Sweden
hi
boca is good tried and tested.
but i had problem with bocas ceramic bearing. after 1 race there was lots of play in it already. i told them, they said return it and they may replace it. i living in australia, couldnt be bothered half way across the world and waiting a month for it to come back. i expect a bit more from a $50 bearing!
i have also tried vxb bearing, they dont seem to roll that free, not bad though, it has stayed very tight after about 1 gallons use. and no play.
qwerty is offline   Reply With Quote
Old 10-11-2005, 04:19 AM   #12
R1 Uffe's Avatar
Originally Posted by qwerty
hi
Thx for that information, if i only order bearings ill order from vxb, if ill order bearings and piston/cylinder ill order from a main hobbies
Old 10-11-2005, 05:04 AM   #13
Suspended
ok thanx Uffe will do.
V-Spec front bearing issues Jonro Nitro Off-Road 35 09-06-2008 11:04 PM
Parts OS V SPEC (NIP boca bearing and carb boot) CRFXXXT R/C Items: For Sale/Trade 6 05-12-2008 06:19 PM
V Spec bearing replacement ! motomanpat Electric Off-Road 1 03-04-2007 09:43 PM
Ceramic Bearing VS Normal Bearing MRX_joe21 Nitro On-Road 25 11-19-2005 11:09 PM
Changing Motor Bearing on Spec 19 Turn Legal? RC Robin Hood Electric On-Road 3 09-29-2005 10:26 AM
