What to do?
What to do?
I'm getting back into the RC'S and I always wanted a buggy.
However I don't know If I want 4wd or 2wd. I think I want 1/10th scale but not certain. I'll be using this on the track for fun/practice and the occasional race.
What do you think? p.s. I don't mind breaking and fixing just not every 5 minutes. Budget is up to 500$ for the truck & parts only. Batteries and radio will be a seperate budget/thread. Local track is dry dusty hard pack.
thanks all,
thanks all,
You can try the Duraguo.
Not a bad suggestion.^
no one uses 1/8 scale at my local track.
also thanks guys but not into sc truck
These threads pop up at least once a week. Get what you want and consider parts support. There are individual threads on pretty much all of the kits available. Go in there and read up on some of the kits that you're interested in to get a good idea.
thanks all,
thanks all,
I agree with a lot of these guys. B5 rear motor is tough to beat. Handle great and are tough. I recommend staying away from 4WD wheeler 1/10 buggies. Even the best drivers break them all the time. I never race mine anymore. Thing will break an arm and shaft even when it looks like it landed a jump perfectly.
urgh this is tougher than I thought I've been given so many ups and downs for both 2wd and 4wd. If my track was sticky I'm almost positive I'd go with 2wd. However my track is dusty and slippery. That being said I'm going the the associated B5 if I go 2wd.
If your track is dry and dusty a 2wd buggy will be frustrating to drive, even a rear motor b5. Most of the current 4wd buggies are more durable than 2wd. Most come with gear diffs which means less maintenance. If there's a 4wd class at your track I would go that direction. A lot more fun to drive on low traction. The reason they seem to break more often is they're usually going faster when you hit something because most guys run 5.5 or 6.5 turn motors. An 8.5 or 10.5 would probably work really well and be easy to drive.
