jammin crt.5 brusshles combo >
Old 02-21-2015, 02:54 AM
Default jammin crt.5 brusshles combo
Hi i know crt have a build thread but with all newer motor and esc ,i would like to have your suggestion, i plan to run on 3s lipo. I know the classic combo castle sct 3800 kv but would check all other possibilitie. Thank to all.
kaven turcotte is offline
Old 02-21-2015, 09:28 AM
ta_man's Avatar
Trader Rating: 165 (100%+)
If you are going to run 3S LiPo I would recommend a Castle 1415 (2400KV) motor or a Novak 7.5 turn Ballistic 550, either with a Mamba Max Pro or a Hobbywing SCT Pro. I have the Novak and MMP in my electric CRT.5. I'm using a 14T pinion with the standard size spur.
ta_man is offline
Old 02-21-2015, 05:31 PM
OK and in the case i will goes with 2s what is your suggestion and what is the best 2/3s????
Old 02-22-2015, 05:57 PM
ta_man's Avatar
If you are going to be running 1/10th scale size wheels & tires (2.2 truck or 2.2/3.0 SCT) then you can use anything that would be appropriate for a 4WD SCT. There's tons of choices. If you want to buy new, a Hobbywing XERUN SCT Pro and 4000KB 3656 motor would be excellent. If you want used, you can find good deals on a Novak Ballistic 550 4.5T or 5.5T along with a GTB ESC. A Castle SCT combo with the 1410 motor and Sidewinder ESC would work too.
If you are going to use bigger tires, then a bigger motor would be called for, a Pro4HD, a T8I, or something similar. The Ballistic 550 would probably work too.
ta_man is offline
