Like Tree10Likes
New Schumacher KF2
    Hide Wikipost
Old 07-29-2016, 08:27 AM   -   Wikipost
R/C Tech ForumsThread Wiki: New Schumacher KF2
Last edit by: MelKF2
Welcome to the KF2 Wiki!
Please feel free to add any Tips, Tricks, or anything that would be beneficial to the KF2 Family
Introduction and Pictures Introduction and Pictures
ElectronicsSetupElectronicsSetups
Setup SheetsSetup Sheets
EmulsionShocksEmulsion Shocks
Tony Newland Gear Diff BuildTony Newland Gear Diff Build
Suggested Gearing
6.5
7.5
8.5
9.5
10.5
13.5
17.5 I ran 69/31 at SRS Scottsdale Arizona and 72/30 at MHOR Aurora Co and Full Throttle ALB, NM RCM lockout worked excellent!
MIP pucks excellent upgrade! The new RCM lockout is an excellent piece as well! These options will greatly reduce weight throughout the drive line!
Print Wikipost
Old 09-19-2017, 12:42 PM
  #1201
Trader Rating: 26 (100%+)
Opinion needed..running in mid motor,graphite chassis with aluminum braces...do I really need the front upper deck ? I 'm running a fan and the deck is getting in the way
thefnshow is online now
Old 09-19-2017, 03:40 PM
  #1202
No, the aluminum braces eliminate the need for the top deck (forward of the motor). I would still run the braces that go between to motor mount and transmission
Riverbluff is offline
Old 09-19-2017, 09:16 PM
  #1203
Old 09-21-2017, 01:14 PM
  #1204
Finally got the Losi wheels to work...fronts worked fine..the tears I had to Drexel a little inside where the but sits and a little where the hex sits...then us Losi 4mm low profile nuts from the 22-4...perfect !
Old 01-12-2018, 12:59 PM
  #1205
dgdcustoms's Avatar
Trader Rating: 85 (99%+)
Can't wait for my 3-cars to show up!!
dgdcustoms is offline
Old 04-23-2018, 04:37 AM
  #1206
lexusbest's Avatar
Hello, i bought a used KF2 SE and i am trying to understand this setup: Schumacher Cougar KF2 - Michal Orlowski - 2016 oOple Race - Robon Hood Raceway - 06-07.08.2016
What does reversed wishbones mean? Differences between sv2 and kit front wishbones?
Is he running rear shock in front of the arm?
How can i add 20g behind the gearbox?
Thanks in advance
lexusbest is offline
Old 04-23-2018, 05:56 AM
  #1207
Thanks in advance
reversed arms means left arm right/right arm left. sv2 arms are shorter and a little flatter. wt behind gearbox try using core rc 10gr. wt x2 and servo tape it to the rear! I think there is a pic in earlier post? battery plate just as good too!
lexusbest likes this.
MelKF2 is offline
Old 04-23-2018, 06:41 AM
  #1208
lexusbest's Avatar
Thank you!
Old 04-23-2018, 12:45 PM
  #1209
Thank you!
anytime! check out Schumacher USA on facebook you can get excellent info there as well!
MelKF2 is offline
Old 12-10-2018, 01:49 PM
  #1210
lmlindbo's Avatar
Got this nib KF2 a few weeks back. Never raced buggies with jumps before.
​​​​​​A few more hours and I'm ready to take a beating by the local klan.
Must say that Schumacher is a nice acquaintance.
Pretty impressed by the quality of this kit
lmlindbo is offline
Old 12-11-2018, 03:32 PM
  #1211
lmlindbo's Avatar
Almost done.
Any tips for a buggy noob before I hit the track?
Jpdanger and Mahjik like this.
lmlindbo is offline
Old 01-11-2019, 05:22 PM
  #1212
lmlindbo's Avatar
Car is more ready than I am.
Going to a race next weekend. First time running a track with jumps. First time running this car. And I will not get any track time before the first qualifier .
Wish me luck....
lmlindbo is offline
