New Schumacher KF2 >
New Schumacher KF2
Like Tree12Likes
New Schumacher KF2
    Hide Wikipost
Old 07-29-2016, 08:27 AM   -   Wikipost
R/C Tech ForumsThread Wiki: New Schumacher KF2
Last edit by: MelKF2
Welcome to the KF2 Wiki!
Please feel free to add any Tips, Tricks, or anything that would be beneficial to the KF2 Family
Introduction and Pictures Introduction and Pictures
ElectronicsSetupElectronicsSetups
Setup SheetsSetup Sheets
EmulsionShocksEmulsion Shocks
Tony Newland Gear Diff BuildTony Newland Gear Diff Build
Suggested Gearing
6.5
7.5
8.5
9.5
10.5
13.5
17.5 I ran 69/31 at SRS Scottsdale Arizona and 72/30 at MHOR Aurora Co and Full Throttle ALB, NM RCM lockout worked excellent!
MIP pucks excellent upgrade! The new RCM lockout is an excellent piece as well! These options will greatly reduce weight throughout the drive line!
Print Wikipost
Old 04-22-2017, 08:17 PM
  #1186
stulec52's Avatar
Trader Rating: 26 (100%+)
hey guys
picked up a nice used KF2 SE recently, and had my first outing with it today.
Anyone got a setup sheet for packed, low grip dirt with some jumps??
also, I'm sure this has been asked, but I could not find it.
running the low grip configuration, how on earth do you get the shorty pack in and out???
thanks
DiscountRCStore likes this.
stulec52 is offline
Old 04-23-2017, 09:11 AM
  #1187
Default KF2
Originally Posted by stulec52
hey guys
thanks
Ok! sounds like you have it in low grip setup! You need to trim down the right side guard to get the battery in-out. You also need the MM configuration (Mid Motor) and if you can mount ESC at right rear! There are pics showing all above in this thread. Hope that helped some!
stulec52 and DiscountRCStore like this.
MelKF2 is offline
Old 04-23-2017, 09:21 AM
  #1188
hey guys
thanks
If you are running on low grip dirt, I would recommend putting it in the MM position (motor all the way back), this allows the rotation of the motor to help produce additional rear traction. Move the rear shocks to the back of the arms, but you'll need to get the rear transmission upper alloy housing for that. Also, flip your front arms, this will give you a bit longer wheel base.
To get the LiPo in and out in the low grip config, you will need to shave down a section on the side pod to allow the battery to slide in and out.
Riverbluff is offline
Old 08-11-2017, 02:23 PM
  #1189
Default kc/kd diff in kf2.
Hi. Does anybody know if the new ball diffs fit the older kf2?
many thanks
PSOMMERTON is offline
Old 08-12-2017, 04:16 AM
  #1190
trevcoll's Avatar
many thanks
KD is gear driven, so a bunch of no on that.
There is a unique part number for the KC ball diff, so guessing that there is a subtle difference from prior models. The OG K1 came with ball diffs and this will also fit the K2, KF & KF2.
trevcoll is offline
Old 08-13-2017, 09:32 AM
  #1191
many thanks
No, the KD and KC have a smaller diameter diff.
ian.joyner is offline
Old 08-14-2017, 05:47 AM
  #1192
Since the belt pitch appears to be the same for the KF2 and KC, how many teeth are on the new diff pulley U4997?
If memory serves, U4196 has 36 teeth.
Also, is the offset of the pulleys (U4196 and U4997) or the assembled diffs (U4199 and U4996) the same?
Typpo is offline
Old 08-18-2017, 08:07 PM
  #1193
So im looking to buy possibly a KF2 buggy for our local indoor track that mainly consists of dirt and clay. We manily run AE and TLR but it would be nice to run something totally different. Would this be a good investment or shall i just look for a KD buggy?
Thanks!
Oaken81 is offline
Old 08-19-2017, 08:19 AM
  #1194
Thanks!
The KD will be an easier buggy to get set up for that surface. If folks are using lay down trans on the AE or TLR, you may want to cisider the KC.
oldernoob likes this.
Old 08-19-2017, 02:17 PM
  #1195
Thanks for the heads up. I may wait to see if i see any used KD for sale then.
Oaken81 is offline
Old 08-25-2017, 05:04 PM
  #1196
Trader Rating: 32 (100%+)
I just picked up a used kf2 se and will be running on high grip astroturf...which position is for high grip..,can't seem to find any info...any help would be appreciated
thefnshow is offline
Old 08-25-2017, 05:53 PM
  #1197
I ran mine in mid motor (motor all the way back) and it was awesome with (Michael O's setup). I bet it would be great in the low traction config as well. I will actually be trying that set up soon.
Old 08-25-2017, 06:32 PM
  #1198
motorcitymatt's Avatar
Here is the setup he's referring to:
Schumacher Cougar KF2 - Michal Orlowski - 2016 oOple Race - Robon Hood Raceway - 06-07.08.2016
If your track isn't bumpy then go with the kit pistons Front and Rear (1.5x3, 1.6x3) and drop 50 Cst in oil. (500 Front, 350 Rear). Make sure your tires are right and you'll be in the ballpark.
motorcitymatt is offline
Old 09-08-2017, 11:26 AM
  #1199
Will the wide track conversion work on a kf2 se ? I'm running into a issue with rims and may have to go to a thinner hex and use the wide track kit to bring it back to normal width
Old 09-19-2017, 11:39 AM
  #1200
never mind,i got the rim situation fixed
