TLR 22T 2.0 Stadium Truck >
Old 07-05-2016, 10:04 AM
  #1471
walterheard's Avatar
Trader Rating: 31 (100%+)
Originally Posted by Frank Root
0mm front limiting, 2mm rear limiting.
From the bottom of the eye lid to the top of the shock ?
walterheard is offline
Old 07-05-2016, 10:08 AM
  #1472
Are you screwing the shock eye lids all the way on the shock shaft? Or do you leave 1mm or etc ?
Old 07-05-2016, 11:54 AM
  #1473
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Mine are screwed all the way in.
Frank Root is online now
Old 07-05-2016, 01:30 PM
  #1474
Trader Rating: 23 (100%+)
screw the eyelid all the way on, and internally limit the rear shocks with a 2mm washer.
electrickid is offline
Old 07-08-2016, 11:50 AM
  #1475
ryan432greening's Avatar
Who's using fans on their motor? When I run indoors it's on carpet with a 17.5 boosted so she gets a little warm. Going to add a fan next week. Let's see your setups!
ryan432greening is offline
Old 07-08-2016, 05:17 PM
  #1476
Trader Rating: 36 (100%+)
I use a fan on my stock vehicles, I get them from here: http://www.shapeways.com/shops/mpp He has several to choose from.
nitrousdave is offline
Old 07-10-2016, 01:31 PM
  #1477
I just built my 2.0 in mm config and I am having trouble fitting my shorty into position. Its a 4400 smc shorty pack and its so tight I have to force it in. Anyone else had this problem?
Drumguy89 is offline
Old 07-10-2016, 02:22 PM
  #1478
TLRacing
Frank Root's Avatar
Some packs fit a bit tighter. I just sanded the front battery mount down a bit until my packs fit well.
Old 07-10-2016, 03:32 PM
  #1479
Thanks for the quick response Frank. Ill get out some sandpaper and see what I can do. I also installed the 3 gear tranny while building the truck. I plan on running mod with the truck. I have heard conflicting information on the 3 gear, some say its for stock racing some say its for high grip applications. Will I have problems running the 3 gear on a mod motor?
Old 07-10-2016, 03:55 PM
  #1480
Another way to do it is to turn around the front part of the mount and space the battery door forward some. Another way yet is this fan mount: http://www.shapeways.com/product/M3A...ionId=30906502 has the legs spread apart to allow the battery all the way against the motor if you wanted to.
Old 07-10-2016, 11:05 PM
  #1481
Jack Bonhomme's Avatar
I ran my truck with a 7.5T motor using the 3 gear tranny on a relatively loose dirt surface last week with no problems. I was using a brick pack though. I increased rear toe to 3.5 and I had plenty of rear traction.
Jack Bonhomme is offline
Old 07-11-2016, 03:25 PM
  #1482
MeasuresMicrons's Avatar
made some changes to the Hobbywing ESC over the weekend and a BIG Thanks to DriveItLikeYSIT, This thing was untouchable. The holeshot was clean and crisp and barely any tire spin if at all. She came out of the tight turns planted and hit the straight running....the long back straight away she'd actually pull the fronts up a bit when she hit the 2nd punch in the ESC, but controllable all away around the track. Jumped and landed amazing.....think she's a keeper.
MeasuresMicrons is offline
Old 07-11-2016, 06:04 PM
  #1483
DriveItLikeYSIT's Avatar
Trader Rating: 93 (100%+)
Racing is fun when you find the right setup. That esc HW setup has always been money for me; I'm glad that it worked out for you..
DriveItLikeYSIT is offline
Old 07-11-2016, 06:18 PM
  #1484
Trader Rating: 166 (100%+)
We finally got the track director where I race to allow the turn marshalls to water the dry patches during wednesday night racing last week, switched to slicks (its that high bite when it's been properly maintained), and wheelie city. Had to basically turn all punch off the speed control, mind you I was running a 6.5 in it (super fun), but a bit of a handful til I remembered to loosen my slipper (was setup for 13.5 stock which I lock the slipper for). Still squeaked out 3rd place with a 6.5 and locked slipper lol...
jpcopeland1 is offline
Old 07-11-2016, 06:28 PM
  #1485
yup. going to back off the slipper a turn and see if she'll keep the nose down. The V10 10.5 just all out rips, I cant imagine anything else in it.
