TLR 22T 2.0 Stadium Truck >
Old 06-09-2016, 04:56 PM
  #1411
Originally Posted by ryan432greening
https://www.youtube.com/watch?v=EToj2yX76NU
Building a TLR 22 Diff with Matt Castellano
Thanks for the link. Watched it and the one after about camber and ride height. Very helpful
Cheers
Grimmlar is offline
Old 06-11-2016, 03:02 PM
  #1412
Jack Bonhomme's Avatar
Frank, I'm almost done with the 3 gear conversion on my rear motored truck. Is it necessary to upgrade to one or both of the rear brass weight systems? One is the 35g hinge pin brace that goes towards the front of the rear arms. The other is the 14g Brass/Alum camber block system at the rear of the truck. I'm running mod so I don't know if I need one or both for proper weight distribution or traction? Also, I usually ran stick packs before. I know I can use my shorty packs, but can I optionally fit a saddle or brick pack with this new tranny configuration?
Jack Bonhomme is offline
Old 06-11-2016, 05:04 PM
  #1413
Originally Posted by masepaulmase
Hi Frank and team
Does anyone have a good carpet set up (mod) for the 22T 2.0?
Cheers in advance.
Paul
Not luck on this one guys?
masepaulmase is offline
Old 06-11-2016, 07:29 PM
  #1414
ryan432greening's Avatar
If someone can tell me how to get a 22T 2.0 to corner tighter and not have T5Ms turning arcs inside of you on carpet, I'm all ears. It's all Associated at my local carpet track in this class.
ryan432greening is offline
Old 06-12-2016, 01:43 PM
  #1415
it's the same at my track on med to high clay.
Dirtraycer is offline
Old 06-12-2016, 05:24 PM
  #1416
walterheard's Avatar
Trader Rating: 31 (100%+)
Just ran the 3 gear tranny in the truck...It made the truck that much better!!! Cornered faster and flatter. Also more control of the truck in the air... Just awesome !!!!!!!!
walterheard is offline
Old 06-13-2016, 04:54 AM
  #1417
I just finished my 3 gear installation and I noticed that my normal 82/17 gear ratio with my 7.5T motor isn'the meshing up anymore. The top motor screw rubs on the spur gear before proper gear mesh is reached. Guess I have to move up to a 84T spur gear? Is the internal gear ratio still 2.43?
Old 06-13-2016, 07:44 AM
  #1418
R/C Tech Elite Member
thecman26's Avatar
Trader Rating: 112 (100%+)
You have these? If not try them!
https://www.amainhobbies.com/lunsfor...lns7932/p77531
thecman26 is offline
Old 06-13-2016, 09:03 AM
  #1419
MeasuresMicrons's Avatar
can I run saddle packs on rear motor? The manual is deceiving and I have BN saddles and would rather not have to buy new batts.
MeasuresMicrons is offline
Old 06-13-2016, 10:42 AM
  #1420
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
You might like the brass anti-squat block, we've run that most of the time in mod. I don't think you'll need both.
In mod, I usually run a square pack, so I'd suggest saddle for you.
Sorry, I've not run the 22T on carpet or astro.
Same internal ratio. If you go 18/84, it's basically the same gearing.
You should be able to, although I've never tried to fit them myself. Two saddle end to end are the same dimensions as a stick pack.
Frank Root is offline
Old 06-13-2016, 04:44 PM
  #1421
Thank you, I have the saddles, (brand new) and just didn't want to buy new batteries. set up today, should be good.
Old 06-13-2016, 10:35 PM
  #1422
tsair's Avatar
I got a chance to run 5 packs through the truck with the new 3-gear.
Initial thoughts:
http://razorrc.tumblr.com/
tsair is offline
Old 06-14-2016, 11:17 AM
  #1423
Lil help Please. Ditching the Hastle Creations, looking at the Reedy Blackbox 10.5T Short Stack combo.......interested in pinion options and can someone explain the advantage or disadvantage to the Short Stack? I don't know anything about it. Local hobby shop has an awesome deal on a couple left.
Old 06-14-2016, 11:45 AM
  #1424
thecman26's Avatar
Unless you run at a huge flowing track where you need the extra rpm's the SS is just gonna run hotter and you'll have less torque. In my opinion that's a lose lose proposition in a truck. Maybe in a buggy where the loss in torque won't hurt much.
Old 06-14-2016, 11:49 AM
  #1425
DriveItLikeYSIT's Avatar
Trader Rating: 93 (100%+)
The short stack motor uses wound pure copper magnet wire and low-resistance collector rings to produce maximum power output and RPM. If your track has loamy or low grip surface then a 10.5t motor will be fine but you might wanna use a lower turn motor for a high grip surface.
The esc in this combo ASC285C-blackbox 10.5t SS is only an 80A esc with a motor limit of 10.5t. You would have to buy a new esc to run a lower turn motor.
DriveItLikeYSIT is offline
