TLR 22T 2.0 Stadium Truck >
Old 06-08-2016, 12:40 PM
  #1396
Trader Rating: 53 (100%+)
Originally Posted by ryan432greening
Are there any aftermarket companies that make a drastically different body for these things? Seems like the creativity would be pretty limited in this division.
Jconcepts makes a body but I like running oem bodies on my tlr cars.
GettinLapped is offline
Old 06-08-2016, 01:17 PM
  #1397
DriveItLikeYSIT's Avatar
Trader Rating: 93 (100%+)
PL makes the enforcer st body for the T5M; I'm not sure if it will fit on a 22T.
I'm currently using the JC Finisher body on my MM 22T
DriveItLikeYSIT is offline
Old 06-08-2016, 02:04 PM
  #1398
ryan432greening's Avatar
Anyone using a Schelle slipper setup on their 22T 2.0? Thoughts? Opinions?
ryan432greening is offline
Old 06-08-2016, 02:30 PM
  #1399
tsair's Avatar
I am (well Avid, but they are the same). We run 13.5t and it dropped a few grams off the drivetrain which was noticeable acceleration-wise. Quick post on this:
http://razorrc.tumblr.com/post/14464...or-not-to-slip
I'm going to try it with some garodisc pads in the next few days.
tsair is offline
Old 06-08-2016, 03:00 PM
  #1400
Do you run a combination of white and red pads? Wondering how that whole tuning side of things works.
Old 06-08-2016, 03:11 PM
  #1401
tsair's Avatar
I run two red and a white. With the TLR trucks, I find the slippers take quite a bit of abuse compared to a buggy. I assume because of the big tires and heavier weight of the trucks. With 13.5 on high-grip, I also don't need/want much slip.
2 or 3 reds is probably the way to go IME.
tsair is offline
Old 06-08-2016, 03:44 PM
  #1402
Your local track lets you race Stadium Trucks against Short Course Trucks? That's awesome for you and not so awesome for them
Haha yeah, it's actually bring what you got 1/10 and under. We don't get points though for the season, it's just for fun as there is only a few of us. It's only club level that we can. When they have big events then Sct only. Hopefully when I get better more ppl will like Stadium truck and we get our own class. When I say better when I'm ripping past everyone they see how good they are
Grimmlar is offline
Old 06-08-2016, 04:06 PM
  #1403
Originally Posted by yoshgixxer
I never had any issues with the stock slipper. And i run a orion 7.5 with 100c batterys. Slipper set to wheelie 3" or so on thr bench. If im rollin a few mph and punch it, it will still wheelie up, but it gives me no issues exiting corners on power
I've rebuilt my ball diff same as Jason Snyder has posted in this forum but no matter how much I tighten slipper it just won't lift. I'm running mm with shorty pack. Any advice. Motor has enough power as lifts in my other stadium truck. Got me stumped
Grimmlar is offline
Old 06-08-2016, 04:24 PM
  #1404
tsair's Avatar
What motor and gearing combo?
tsair is offline
Old 06-08-2016, 04:36 PM
  #1405
Default Left or Right for ball diff
Hi. Was doing some browsing and someone mentioned that the ball diff nut is on the left side looking from the back. However. I'm sure the manual says that this is correct IF your running rear motor setup and it's on the right for Mid Motor. Is this correct maybe I've got mine wrong hence it won't lift during slipper test
Grimmlar is offline
Old 06-08-2016, 04:38 PM
  #1406
It's a Orion 13.5t combo. Basic combo. Gearing I'm not sure. But same combo in another truck is good and it lifts
Grimmlar is offline
Old 06-09-2016, 08:43 AM
  #1407
Mudcat981's Avatar
By the manual its on the Left looking from the rear, RM & MM.
Mudcat981 is offline
Old 06-09-2016, 09:27 AM
  #1408
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Performance wise, it doesn't matter which side of the car the diff screw head is on. I always put it away from the slipper/spur so that it is easier to access for adjustment.
Watch Matt Castellano's diff and slipper video we did a while ago. I haven't seen the Jason Snyder video, but I know Matt's is spot on.
Frank Root is offline
Old 06-09-2016, 10:15 AM
  #1409
https://www.youtube.com/watch?v=EToj2yX76NU
Building a TLR 22 Diff with Matt Castellano
Old 06-09-2016, 04:23 PM
  #1410
Hey thanks guys. I'm glad you said it doesn't matter what side the diff nut goes because mine is in the right away from slipper. I've got the manual and it definitely says left side for rm and right side for mm. However lol this is the manual for the 22t. Not the 2.0. I know this is 2.0 thread but didn't think it would make a difference. Thanks guys
Edit: looking on 2.0 manual it does say left side. Mentions nothing about rm or mm. Quick look on my phone
Grimmlar is offline
