TLR 22T 2.0 Stadium Truck >
Old 06-07-2016, 09:40 PM
  #1381
Default Cool combo recommendations
Hi. New member here. Ive only ever had sensorless combos and been ok with that, but want to step it up and go Sensored. For my TLR 22T stadium truck, what would be a decent combo and pinion size that would keep everything cool. From reading a gabillion threads already I think I'll go with Hobbywing as reviews say there good without costing as much as higher brands.
I mainly bash. But will be starting racing against 2wd sct when I get suitable combo.
Grimmlar is offline
Old 06-07-2016, 09:41 PM
  #1382
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Originally Posted by DriveItLikeYSIT
Would you include a 10.5t motor in spec racing? That is, would you recommend a 3 or 4 gear tranny with a 10.5t motor on a low to med grip track?
That's hard to say
Frank Root is offline
Old 06-07-2016, 11:47 PM
  #1383
Stevomatik's Avatar
Hobby wing is good I'm a huge fan of their motors so I say go for it
Stevomatik is offline
Old 06-08-2016, 06:09 AM
  #1384
ryan432greening's Avatar
I'm currently running a 10.5t and the 4 gear on medium grip and with whatever tires work great at your track, I would guess that you will be just fine. I'm on M3 Holeshots on 70-80 degree days and happy as a clam.
All I did was throw the low frequency springs on (on the lighter side of the kit) for rear traction and to create a little bit of roll to bite into the turn and settle down some bounciness. I also tipped the shocks all the way in.
ryan432greening is offline
Old 06-08-2016, 07:36 AM
  #1385
DriveItLikeYSIT's Avatar
Trader Rating: 93 (100%+)
Thanks for the info! I'm also using a 4 gear tranny and m3 or m4 holeshots at medium sized outdoor track in FL. My st handles well; I run AE 32.5wt shock oil & green springs in the front w/ AE 27.5wt oil & silver in the rear.
My st isn't in this video it's just for your viewing pleasure http://youtu.be/duPPiz0g72A
I'll prob install the 3 gear tranny at indoor, high grip track w/ a 17.5t motor
DriveItLikeYSIT is offline
Old 06-08-2016, 07:57 AM
  #1386
That place looks like a hoot, where in FL?
Old 06-08-2016, 08:05 AM
  #1387
Originally Posted by Frank Root
That's hard to say
Your local track lets you race Stadium Trucks against Short Course Trucks? That's awesome for you and not so awesome for them
Old 06-08-2016, 08:45 AM
  #1388
Yeah its a new facility in Lake City which is in north FL in between Tallahassee and Jacksonville.
Old 06-08-2016, 09:30 AM
  #1389
Well if you grab some footage of the 22T 2.0 running on the big track it would be cool to see.
Old 06-08-2016, 09:31 AM
  #1390
What do you TLR faithful that pay close attention think will be coming in the 3.0 kit in the future? What changes might they make and what issues do you think will be addressed?
Old 06-08-2016, 09:39 AM
  #1391
Mudcat981's Avatar
I still think the 3.0 is a long way off, but I would suspect and change similar to the 22 3.0 chassis.
Mudcat981 is offline
Old 06-08-2016, 09:42 AM
  #1392
SO, variable length front arms, shorty battery facing forward to back or sideways, some rear end changes that are allowed by ditching the rear motor option?
Old 06-08-2016, 11:23 AM
  #1393
Will do! I use a RM config when it's loamy and bets around pretty well, see pic below. When traction improves then I is use MM. My MOD MM exotek 22sct 2.0 is very fun to drive this track..
Old 06-08-2016, 12:06 PM
  #1394
Trader Rating: 53 (100%+)
Hopefully the 3.0 comes with a freshly designed body. It's time for a refresh already they been using that body for way too long. Pretty please frank.
GettinLapped is offline
Old 06-08-2016, 12:27 PM
  #1395
Are there any aftermarket companies that make a drastically different body for these things? Seems like the creativity would be pretty limited in this division.
