TLR 22T 2.0 Stadium Truck >
Old 05-16-2016, 06:16 PM
  #1321
Yeah I want the New Losi 3.0 Stadium Truck as well.
Sticking with Losi Trucks. Ive got the 2.0 Corr Truck so I might as well get the Stadium Truck also.
If 4wd Corr Trucks make a comeback here I'll get the SCTE also.
bmag5000 is offline
Old 05-17-2016, 09:36 AM
  #1322
MNiceGuy's Avatar
For those of you that have performed the Exotek chassis conversion:
On fast turns, does your truck have a tendency to quickly, and sometimes unexpectedly, rotate? I'm running on high-traction and I find that as my truck approaches the limit, the front will grab hard and suddenly the back end wants to come around.
I'm running kit setup except black front springs and brass rear hinge pin mount.
MNiceGuy is offline
Old 05-17-2016, 10:26 AM
  #1323
tsair's Avatar
I'm getting a little bit of what you are talking about, but in slow->medium speed turns. I don't know if it's lack of chassis flex, or battery placement or what. I have the battery full forward transverse. Moving the shocks all the way inward on the tower seems to have helped a little.
tsair is offline
Old 05-17-2016, 02:00 PM
  #1324
MNiceGuy's Avatar
Thanks for the info. Do you recall experiencing the same thing with the original chassis?
MNiceGuy is offline
Old 05-17-2016, 04:17 PM
  #1325
tsair's Avatar
No, but so much has been changing between my local track and my truck, so hard to say what the cause is.
tsair is offline
Old 05-17-2016, 05:21 PM
  #1326
DriveItLikeYSIT's Avatar
Trader Rating: 93 (100%+)
i was having the same issue with my exotek 22T 2.0 until I moved the rear wheel base back; I'm using 3MM in spacers on the arm in front on the hub & 1MM behind the hub. I also use stiffer shock springs (KYO gold & front) at an indoor high bite track...
DriveItLikeYSIT is offline
Old 05-17-2016, 10:14 PM
  #1327
tsair's Avatar
Our track is high-grip clay, and I'm going to try removing the brass hinge pin mount. I have a feeling it's not really needed with the Exotek, since there is so much weight already down low. Might reduce the pendulum effect too.
tsair is offline
Old 05-19-2016, 02:31 AM
  #1328
KalEl63's Avatar
Just wondering if anyone is running the Spektrum S6270 servo in their truck and if so what is it like?
I知 looking to get some new servos and they seem to be the ones I知 interested in the most
KalEl63 is offline
Old 05-19-2016, 05:03 AM
  #1329
R/C Tech Elite Member
thecman26's Avatar
Trader Rating: 112 (100%+)
For $99? Not totally sold on low profile servos myself. I could name several regular servos for less $.
thecman26 is offline
Old 05-19-2016, 08:12 AM
  #1330
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
I have a S6270 in my stock buggy, and I've been happy with it.
Frank Root is offline
Old 05-19-2016, 09:25 AM
  #1331
MeasuresMicrons's Avatar
Frank, I was wondering if you could give me a bit of advice Please? I plan on running the 22T 2.0 with the kit set up, Castle Creations SCT 3800kV motor on saddle pack 5700mAh 50C. Bumpy, loose, tight track with some big jumps. Just curious on a what pinion to keep her under control. Plan on running the kit spur gear unless you have better a option.
Thank you.
MeasuresMicrons is offline
Old 05-19-2016, 09:48 AM
  #1332
TLRacing
Frank Root's Avatar
Thank you.
Try 1.6mm pistons all around with 35 front and 30 rear oil.
Old 05-19-2016, 09:57 AM
  #1333
Thank you kind sir, any recommendations for a pinion?
Old 05-19-2016, 11:24 AM
  #1334
TLRacing
Frank Root's Avatar
Sorry, I am not familiar with sensorless motors and their gearing.
Old 05-19-2016, 11:31 AM
  #1335
Understandable, we're starting to run these 1/10s between the cool down period for the 8's. Trying to get a base line and work off that. Thanks anyway.
Would the Reedy 8.5T be a comparable set-up?
