TLR 22T 2.0 Stadium Truck >
Old 04-28-2016, 12:00 PM
  #1276
MNiceGuy's Avatar
Originally Posted by Frank Root
http://www.tlracing.com/Products/Def...odID=TLR332056
We have a 3-gear tranny for the 22 2.0 vehicles (included the 22T 2.0 and 22SCT 2.0) that will release in May 2016. It included the motor plate, tranny cases, water fall, spacer, and an aluminum idler. Get one on back order today!
For those of us that have done a chassis conversion and have a non-TLR waterfall, is the one included in this kit the same as the original, 4-gear version?
MNiceGuy is offline
Old 04-28-2016, 02:21 PM
  #1277
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
It is not, the long side will need to be machined/ground down to the be the same length as the short side.
Frank Root is offline
Old 04-28-2016, 02:45 PM
  #1278
tsair's Avatar
I assume (hope) this is compatible with the Exotek chassis?
tsair is offline
Old 04-28-2016, 03:05 PM
  #1279
TLRacing
Frank Root's Avatar
I'm not familiar with their chassis, but it fits the TLR 2.0 chassis' without modification so I'd *assume* it would fit theirs. You might check with the guys over at Exotek to be sure.
Old 04-28-2016, 04:45 PM
  #1280
DriveItLikeYSIT's Avatar
Trader Rating: 93 (100%+)
Just to clarify, is the 3 gear tranny compatible with the legacy 22sct?
DriveItLikeYSIT is offline
Old 04-28-2016, 04:48 PM
  #1281
TLRacing
Frank Root's Avatar
Yes, 1.0 or 2.0.
Old 04-28-2016, 04:52 PM
  #1282
Yes, 1.0 or 2.0.
Thanks for replying so quickly! Sorry for posting on the wrong thread; i've been bouncing back and forth between the 22t and 22sct threads..
Old 04-29-2016, 05:41 PM
  #1283
Does the new transmission change the motor position in relation to the diff?
sealclubber253 is offline
Old 04-30-2016, 09:06 AM
  #1284
tsair's Avatar
Frank replied in another thread that the motor stays in the same spot.
tsair is offline
Old 05-02-2016, 07:24 PM
  #1285
larsif's Avatar
How do you remove the side ballast weight from the pods? They are not screwed in but I can not get them out. Do you have to use a screwdriver to pry them out?
larsif is offline
Old 05-03-2016, 07:41 AM
  #1286
Trader Rating: 28 (100%+)
Just wondering what does everyone run for antiquated on high bite clay..1 or 2 degrees? Buggy was 2 degrees but truck says 1. What would be the difference?
dbracn is offline
Old 05-03-2016, 08:35 AM
  #1287
Mudcat981's Avatar
They are a tight fit, I have to use something to pop them out. Doesn't take much force just something to grab with.
Mudcat981 is offline
Old 05-03-2016, 12:32 PM
  #1288
Team Pink's Avatar
Trader Rating: 20 (100%+)
I don't have the truck yet as I plan on getting one within a few weeks. However, I can answer your question. One degree of antisquat should provide more side bite through the corner; where two degrees will free the buggy/truck up. I have also found more antisquat to give a little more pop off jumps as well.
Team Pink is offline
Old 05-03-2016, 03:02 PM
  #1289
tsair's Avatar
I have the original T2.0 chassis, the lightweight TLR T2.0 chassis, and the Exotek chassis and thought it'd be useful to share my weight difference findings.
- Weight -
Box T2.0 chassis: 133g
Lightweight T2.0 chassis: 101g
Exotek T2.0 chassis: ~128g*
*The Exotek chassis is counting a change from my Exotek battery tray + inline battery mount to the Exotek battery strap, so it's not an exact apples to apples comparison since the battery trays are different. But this should give you an idea of the weight differences.
So for stock racing, the lightweight/milled TLR chassis is probably going to be the best choice. For loose conditions, I imagine the Exotek transverse battery will be best. I'll provide more of my thoughts when I get a chance to run it.
tsair is offline
Old 05-03-2016, 03:06 PM
  #1290
tsair's Avatar
http://www.rcdriver.com/tune-with-anti-squat/
tsair is offline
