TLR 22T 2.0 Stadium Truck >
Old 04-13-2016, 07:51 AM
  #1261
walterheard's Avatar
Trader Rating: 31 (100%+)
Does anybody know if the jconcepts body makes the truck drive different than the tlr stock body ?
walterheard is offline
Old 04-13-2016, 09:00 AM
  #1262
Mudcat981's Avatar
Nope, JConcept has a better wing and mounting.
Mudcat981 is offline
Old 04-13-2016, 09:43 AM
  #1263
One isn't more or less aggressive than the other ?
Old 04-13-2016, 11:05 AM
  #1264
Mudcat981's Avatar
Not that I can tell.
Old 04-13-2016, 11:31 AM
  #1265
Trader Rating: 41 (100%+)
Originally Posted by dbracn
Just picked up a truck and wondering if the aluminum bulkhead from the buggy will work? If so what is the effect of the added weight on the front of the truck
The one from the buggy will only get you to 25 degrees of kick with that insert. The 22T kit setting is 30 degrees and what most people run. So yes part tlr1072 will work but will change the kick angle. Tlr1105 is the aluminium part for 30 degree that doesn't use any additional shims.
As for what reducing kick will do I think there is a decent write up on tlr's website blog. May have to search back a ways.
On my scale the stock 30 plastic part is 9 grams. The buggy alum with plastic 25 shim is 16 and the alum 30 is 17. I run the alum 30 on both rear and mid motor. I think the extra weight in front helps the mid motor turn a little better. I don't notice as much in rear motor.
E-Mann is offline
Old 04-24-2016, 07:44 PM
  #1266
Anybody try vrp pistons in the truck ?
Old 04-25-2016, 08:23 AM
  #1267
mvrk28's Avatar
Ya i had them in mine before it was stolen, I don't remember what size I had in it but they were great. I run VRP in all of my stuff.
mvrk28 is offline
Old 04-27-2016, 10:44 PM
  #1268
Maybe a little setup tuning, and some advice on how to set the slipper, diff, bleed shocks, etc.[/QUOTE
Hi I'm new to racing and have only the 22T at this stage with a couple of 2.0 parts. Can you link a post or give me a little advice on the above. I've looked on YouTube how to build and set ball diff and slipper, but bleed shocks? What do you mean there.
So can you tune the diff and slipper to suit my own driving style. If so, how will I know lol. Outside track. Loose if you get of race line.
Noobess is offline
Old 04-28-2016, 04:41 AM
  #1269
Trader Rating: 36 (100%+)
Frank, I just noticed the 3 gear gearbox has been released and noticed the larger aluminum idler gear. Is the trans ratio still 2.43 with this gearbox?
nitrousdave is offline
Old 04-28-2016, 05:32 AM
  #1270
Henry#40's Avatar
Ratio will be the same, the idler size doesn't affect gearing.
Henry#40 is offline
Old 04-28-2016, 09:05 AM
  #1271
Mudcat981's Avatar
Here is how to rebuild your shocks.
https://www.youtube.com/watch?v=Eq9BCf6EjEQ
Old 04-28-2016, 09:07 AM
  #1272
Mudcat981's Avatar
Where is this 3 gear tranny? I don't see it on the TLR site?
Old 04-28-2016, 09:30 AM
  #1273
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Yes
What he says
Frank Root is offline
Old 04-28-2016, 09:33 AM
  #1274
Matt Trimmings's Avatar
Trader Rating: 170 (100%+)
http://www.tlracing.com/Products/Def...odID=TLR332056
Matt Trimmings is offline
  #1275
TLRacing
Frank Root's Avatar
We have a 3-gear tranny for the 22 2.0 vehicles (included the 22T 2.0 and 22SCT 2.0) that will release in May 2016. It included the motor plate, tranny cases, water fall, spacer, and an aluminum idler. Get one on back order today!
