TLR 22T 2.0 Stadium Truck >
Old 04-06-2016, 09:00 AM
  #1246
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Originally Posted by walterheard
For this truck which gives better performance ? Brick pack or shorty ?
Brick for Mod
Shorty for Open
Frank Root is offline
Old 04-07-2016, 06:51 PM
  #1247
walterheard's Avatar
Trader Rating: 31 (100%+)
Originally Posted by Frank Root
Brick for Mod
Shorty for Open
Frank. The manual has 2mm washer under front inner ball stud. But set up sheet has 1mm. Which is stock set up
walterheard is offline
Old 04-07-2016, 11:16 PM
  #1248
tsair's Avatar
I found 2mm to work better for me and give a little more front tire grip on corner entry.
tsair is offline
Old 04-08-2016, 12:13 AM
  #1249
TLRacing
Frank Root's Avatar
2mm
Old 04-08-2016, 12:29 AM
  #1250
Hi,
I have recently purchased a TLR 22t 2.0 already built and rtr. I noticed it has side pods, but they are cracked along the inside.
Just wanting some insight on where to purchase them from.
Jack
JackG is offline
Old 04-08-2016, 04:12 AM
  #1251
Originally Posted by JackG
Hi,
Jack
http://www.speedrc.com/product/team-...rd-set-222-0t/
hyper7driver is offline
Old 04-09-2016, 08:21 PM
  #1252
I need some help getting rid of a terrible front-end push. I can't get the truck to turn in like I want it to without sliding the rear with either throttle or brake input.
Inputs:
Loose track, lower grip
Rear motor setup w/ stick lipo
So far I've played around with tires and my biggest improvement has been by putting Holeshots on the front. I then softened up the front a bit through spring tension, however I am now lower than the recommended ride height range according to the manual.
Can someone tell me what to adjust and in what order? I know tires are most important and I think I've got the right tires now, so am I way off on the tune?
csmorris is offline
Old 04-09-2016, 09:21 PM
  #1253
Going from a full sized stick to a standard light weight shorty may help to provide the single biggest change you are looking for to free up the rear end, if it already is planted or too planted w a full size lipo battery in the rear motor configuration as you describe now. (You can move the shorty once you get one to try out in different positions too to get the balance you're looking for as well. Just an idea worth trying perhaps if everything else is right, I.e. tires, set-up.)
4wd Racer is offline
Old 04-10-2016, 06:17 PM
  #1254
I have a question for you guys. ive been fighting going mid motor for a about a year but after many 2nd and 3rd place finishes it's time to go mid motor. so I converted the truck to mm per the manual. but something in the transmission is binding. I put the trans together and outside the truck it spins smooth. put it in the truck and it no longer spins freely. there is nothing hitting the slipper plate and the truck is built per the instructions. I've taken it apart 3 times with the same result each time. please help!
sandwich949 is offline
Old 04-10-2016, 07:20 PM
  #1255
Kings Kid's Avatar
Trader Rating: 35 (100%+)
I have found that if you over tighten the transmission case screws into the motor plate it can create a bind. Turn them until they're just snug and that should stop the bind
Kings Kid is offline
Old 04-10-2016, 08:20 PM
  #1256
Did you replace the plastic insert in the inner-rear pivot? In mid-motor you need to match the inserts to the anti-squat shim you are running. The correct parts will allow the transmission to sit level, compensating for the height of the pivot.
In rear-motor there is just one insert, and the screws actually thread into it instead of pass through.
Christophoclese is offline
Old 04-11-2016, 07:50 PM
  #1257
Trader Rating: 36 (100%+)
Check around here: http://www.rctech.net/forum/electric...l#post14165826
The binding trans has been discussed before, there are several solutions.
nitrousdave is offline
Old 04-11-2016, 11:18 PM
  #1258
thank you guys. I used a dremel around the idler and fixed it right up.
Old 04-12-2016, 09:24 PM
  #1259
Trader Rating: 28 (100%+)
Just picked up a truck and wondering if the aluminum bulkhead from the buggy will work? If so what is the effect of the added weight on the front of the truck
dbracn is offline
Old 04-12-2016, 09:27 PM
  #1260
tsair's Avatar
Yes, and generally will add more traction to the front end of the car.
tsair is offline
