TLR 22T 2.0 Stadium Truck >
Old 03-30-2016, 01:40 AM
  #1231
does anyone know if the TLR1072 aluminum Front pivot is 30 deg or 25 deg I looked it up on AMain but couldn't find out what it was.
Dirtraycer is offline
Old 03-30-2016, 05:22 AM
  #1232
Neither...that part must be used with a kick shim to get the desired angle. There are 20, 25 and 30 degree kick shims available.
-W
Wanderer77 is offline
Old 03-30-2016, 06:16 AM
  #1233
Originally Posted by JackG
Hi there I have just purchased a TLR 22t second hand and noticed it came with some side pods however I have noticed they do not come from a company and that people have been custom making them.
Any guidance on where to purchase them and whatnot is appreciated.
Yours Sincerely,
Jack
Viking Design Works makes side pods allowing you to mount your batteries sideways. They also make a 3 gear tranny and other parts for TLR.
http://www.facebook.com/vikingdesignworks/
ezimmerman is offline
Old 03-30-2016, 09:11 AM
  #1234
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
That pivot works with the 20 and 25 deg kick shims.
-W
Not true, there is no 30 deg kick shim, and you'll need the molded or aluminum 30 deg pivot.
Frank Root is offline
Old 03-30-2016, 09:57 AM
  #1235
Thanks for the correction Frank! I was thinking I had seen a 30 deg shim, but I guess I remembered wrong.
-W
Old 03-30-2016, 12:32 PM
  #1236
thanks for the info. now the seller on ebay is ignoring my messages I've been trying to stop it since this morning !
Old 04-01-2016, 06:12 AM
  #1237
Kings Kid's Avatar
Trader Rating: 35 (100%+)
Any way to contact them away from Facebook
Kings Kid is offline
Old 04-01-2016, 06:30 AM
  #1238
Here is the website...
http://www.vikingdesignworks.com/
-W
Old 04-01-2016, 09:02 AM
  #1239
Kings Kid's Avatar
-W
Thank you for the link I'm not seeing anything but three Gear transmission parts I don't see the side pods on their website.
Old 04-01-2016, 10:42 AM
  #1240
Sorry, I don't know anything about their side pods. I only knew the website, because I have been considering their 3 gear transmission and an Exotek chassis ever since I started running my 3.0 buggy.
-W
Old 04-01-2016, 04:24 PM
  #1241
if you click on the 3gear tranny link there are pictures of the battery kit. they have a complete kit that comes with a new waterfall, battery post and strap , along with mudguards to hold the shorty pack in sideways. for $55 or $35 for just the mudguards. I bought a set of the mudguards for my truck and get to test tomorrow.
would be faster and more info on the Facebook page.
Old 04-01-2016, 08:22 PM
  #1242
larsif's Avatar
Originally Posted by E-Mann
Yes it will work. Assuming you have bleeder shock caps. I ran one like this for a while. Unscrew the bottom about 2mm and run a 1mm spacer on the outside of the shock body. Basically you want as much stoke as you can get without the piston going past the top of the shock body. The longer shocks do make an improvement but mainly on bumpy surfaces. If you are running mid motor and on a high bite surface you may not notice much as some 2.0 setups reduce droop / stroke.
You will also need longer turnbuckles and use the HD ball cups. When you say rear axels you actually need the longer drive shafts and axel. You don't need the hinge pins but the threaded versions on the hubs are much better for servicing than the 1.0 with the clips. Don't forget the 22 SCT hexes.
Really if you can get $100 for your 1.5 roller you will be money ahead selling it and buying a new kit.
Thank you for the info.
larsif is offline
Old 04-02-2016, 11:00 PM
  #1243
walterheard's Avatar
Trader Rating: 31 (100%+)
Any suggestions on how I can make my car push a little, so I can drive it harder ?
walterheard is offline
Old 04-03-2016, 07:55 AM
  #1244
This is all exactly correct.
Erik, the owner of Viking Design Works is an awesome guy. He'll respond quickly and directly to Facebook messages. I have the side pods on my 22T, they mounted up quickly, look great, and the truck works awesome!!
Old 04-05-2016, 08:32 PM
  #1245
For this truck which gives better performance ? Brick pack or shorty ?
