TLR 22T 2.0 Stadium Truck >
Old 01-24-2016, 03:44 PM
  #1081
gokarter64's Avatar
Running a shorty pack sideways vs inline makes the car a lot easier to drive fast, the exotek chassis is wider and it allows you to do this without machining anything. the stock chassis when modifyed to run sideways shorty becomes a wet noodle and has way too much flex. These chassis are actually a bit stiffer than stock due to the use of carbon fiber for the side rails
gokarter64 is offline
Old 01-24-2016, 04:40 PM
  #1082
ok great thank you sooo much for that response i just ordered one. thanks again
DIRT DIGGER is offline
Old 01-25-2016, 10:51 AM
  #1083
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Originally Posted by 350lt1
Hi guys,
I just finished assembling a TLR 22T 2.0 and the differential keeps slipping. I tightened it and comes lose again and again. I took it apart to see if I missed something while assembling but no luck. Everything just seems right, except that it keeps losening.
Any guesses on what could it be or were should I double check?
Sounds like you might need to break it in better before starting. Then you'll always keep it a little on the tight side for 3-5 runs as it will loosen slightly as it breaks in.
https://www.youtube.com/watch?v=EToj2yX76NU
Frank Root is offline
Old 01-27-2016, 10:12 PM
  #1084
sleddriver's Avatar
Has anyone used the Protek 130SS steering servo with the 22T 2.0? What shims do I need to use? Do any of you like to ream hinge pin holes? What size reamer do I need? Is it a 3mm?
sleddriver is offline
Old 01-28-2016, 06:52 AM
  #1085
Jack302's Avatar
Trader Rating: 22 (100%+)
Questions??
Originally Posted by DriveItLikeYSIT
Did anyone get this? opinions?
Jack302 is offline
Old 01-28-2016, 06:56 AM
  #1086
Jack302's Avatar
Questions??
I just put mine together but i have not run it yet. When i get some electronics for it ill do a comparison. Based on my experience with my 22 2.0 it was a whole different car when i changed to the exotek chassis so i expect the 22t to act similarly
Post some pics once you get it set up to run please.
BTW Nice paint job are the shark teeth stickers?
Jack302 is offline
Old 01-28-2016, 01:45 PM
  #1087
does anyone know what will change if i go from 1 degree anti squat to 2 degress?
Old 01-28-2016, 01:55 PM
  #1088
68pontiac's Avatar
Less side-bite, more forward bite, less ability to handle bumps/ruts, more air off jumps.
68pontiac is offline
Old 01-30-2016, 02:29 PM
  #1089
Jack302's Avatar
Is there going to be a 3.0?
Jack302 is offline
Old 01-30-2016, 07:36 PM
  #1090
This truck just came out, I wouldn't look for a 3.0 for atleast a year. Even then it would be subject to how well the class is doing. Just My .02
Dirtraycer is offline
Old 02-01-2016, 03:55 AM
  #1091
I would think a 3 gear tranny would be in the near future for MM. Which could justify a new 3.0 that consist of all new rear suspension and a redesign of the back half of the chassis.
hyper7driver is offline
Old 02-01-2016, 04:15 PM
  #1092
hello im wondering what the best ride height would be for a med bite indoor track? please help.
Old 02-01-2016, 04:56 PM
  #1093
gokarter64's Avatar
it may be a while due to a small budget.
the shark teeth are painted, and according to the guy i had paint my bodys they were a pain in the ass to mask
Old 02-01-2016, 05:20 PM
  #1094
tsair's Avatar
Kit setup works for me.
tsair is offline
Old 02-01-2016, 06:38 PM
  #1095
29-30mm Front with 28mm Rear would work fine.
If anyone's interested I have an extra NIB 22T 2.0 kit for sale also.
4wd Racer is offline
