TLR 22T 2.0 Stadium Truck >
Old 01-17-2016, 02:41 PM
  #1066
Originally Posted by donny939
I recently converted my 22t1.0 to a 2.0. And I broke a hub. Just for the heck of i looked at the other hub an noticed a groove in it that wasn't there when it was new. Any ideas what happened
. I took pix but I dunno how well you can see it.
CVA pin was probably backing out and cut into the hub carrier.
Christophoclese is offline
Old 01-17-2016, 10:00 PM
  #1067
Yea that's what I think.. I replaced the hub, I'll keep it as a spare. I re thread locked the set screw that holds the pin. I probably didn't let it set long enough
donny939 is offline
Old 01-18-2016, 04:19 PM
  #1068
does anyone know if the kit comes with 2x1.5 and 2x1.6 shock pistons? also what springs come with kit? thanks
DIRT DIGGER is offline
Old 01-18-2016, 07:05 PM
  #1069
Trader Rating: 52 (100%+)
Yes, 1.5 and 1.6 piston with blue springs up front and yellow out back.
GettinLapped is offline
Old 01-19-2016, 11:46 AM
  #1070
Default 22t 2.0 diff help!
Hi guys,
I just finished assembling a TLR 22T 2.0 and the differential keeps slipping. I tightened it and comes lose again and again. I took it apart to see if I missed something while assembling but no luck. Everything just seems right, except that it keeps losening.
Any guesses on what could it be or were should I double check?
350lt1 is offline
Old 01-19-2016, 12:01 PM
  #1071
Mudcat981's Avatar
Originally Posted by 350lt1
Hi guys,
Check the diff as to which way it is installed.
Looking from the rear the bolt should be adjustable from the left side. I have had it installed the other way and have had it loosen.
Mudcat981 is offline
Old 01-19-2016, 12:35 PM
  #1072
Its on the left side.
350lt1 is offline
Old 01-19-2016, 01:22 PM
  #1073
Mudcat981's Avatar
How many runs? If only a few new diffs will need to be tightened after the first couple of runs. Or maybe the nut is bad, try replacing it.
Old 01-19-2016, 01:24 PM
  #1074
HBRob's Avatar
Trader Rating: 61 (100%+)
Hi guys,
Check the thrust bearings. If they are dry or have a bad ball, this will cause the diff to loosen as it wont slip.
HBRob is offline
Old 01-20-2016, 11:15 PM
  #1075
Anybody run the aluminium rear hubs? I broke a couple plastic and just wondering if I should switch
donny939 is offline
Old 01-23-2016, 08:30 AM
  #1076
building my kit now does anyone know what i set the stroke for shocks? i dont see no measurments.
Old 01-23-2016, 09:52 PM
  #1077
also curious if anyone has used the exotex chassis? im wondering if its worth the money and any noticeable differences over the stock chassis? thanks
Old 01-23-2016, 11:18 PM
  #1078
vintage tone's Avatar
Trader Rating: 19 (100%+)
HAs anyone experimented with monster truck / vintage truck / muscle cars bodies on the 22T ??
I know you can t race them but I d like to do a couple for fun.
vintage tone is offline
Old 01-24-2016, 01:30 AM
  #1079
gokarter64's Avatar
I just put mine together but i have not run it yet. When i get some electronics for it ill do a comparison. Based on my experience with my 22 2.0 it was a whole different car when i changed to the exotek chassis so i expect the 22t to act similarly
gokarter64 is offline
Old 01-24-2016, 10:37 AM
  #1080
Thanks i just wasnt sure how different it would be they both look very similar so i wasnt sure what effects it would have.
