TLR 22T 2.0 Stadium Truck >
Old 01-10-2016, 06:20 PM
  #1051
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Originally Posted by DIRT DIGGER
hey frank what kind of weight would need to be added for a low bite track??
I run a square/brick/saddle pack setup everywhere and only add the brass anti-squat block.
Originally Posted by walterheard
Anybody test a gear diff with this truck on low bite track ?
You'll give speed and consistency, but gain durability.
Frank Root is offline
Old 01-10-2016, 06:42 PM
  #1052
walterheard's Avatar
Trader Rating: 31 (100%+)
Gear diff would be less consistent than ball diff ?
walterheard is offline
Old 01-10-2016, 07:27 PM
  #1053
tedstryker's Avatar
Trader Rating: 88 (100%+)
I'm running gear diff with 2k oil I like how the truck responds with a gear diff
tedstryker is offline
Old 01-10-2016, 07:29 PM
  #1054
What type of track conditions ?
Old 01-11-2016, 07:16 AM
  #1055
TLRacing
Frank Root's Avatar
Yes, it loosens throughout a run as the oil heats, but more than that, it locks up the rear under acceleration, or diffs out the inner tire. Very inconsistent when driving moderately hard to hard.
Old 01-11-2016, 12:20 PM
  #1056
tedstryker's Avatar
Gear diff has a better throttle response to me in my 22T then ball diff do to the fact there is zero slipping. Gear diff will come outta the corners alot harder when on med to high bite tracks also Less maintenace. For me I will never go back to ball diff again especially after having them in my 4wd buggy I think gear diff will be the go to since all these tracks are becoming super high bite.
Old 01-16-2016, 06:59 PM
  #1057
fievel's Avatar
Not having a great time with my 22T 2.0 and I think it's because I have a motor that may be a little too fast for my ability. This is my first 2wd vehicle and I am running a 7.5T. I just can't seem to get the required throttle control to come out of corners hard. How much of a difference is there between a 7.5 and let's say a 8.5 or 9.5?
Currently running no timing.
Thanks for your help.
fievel is offline
Old 01-16-2016, 08:11 PM
  #1058
Can't you run negative timing or turn the epa (ow whatever you call it on your radio down so you don't get full power.. Also set the slipper a lil looser. I run 8.5 and it's perfect. Gotta get used to coming out of turns but it's nice being able to walk up to jumps and just punching it and clearing it no problem. The esc also has setting you could mess with too. I'd try all that before you buy a new motor.
donny939 is offline
Old 01-16-2016, 08:15 PM
  #1059
fievel's Avatar
I was gonna try expo but people always say not to use it.
fievel is offline
Old 01-17-2016, 07:37 AM
  #1060
hows this truck on low/med bite indoor dirt that gets very slick and dusty? im running a t5m and its terriable its very inconsistent and coming in and out of corners its super skatey in the rear. im wondering if this is an easier driving truck and a good setup for it? thanks alot
DIRT DIGGER is offline
Old 01-17-2016, 10:20 AM
  #1061
Trader Rating: 137 (98%+)
i just went to the 22t 2.0 over the t5m the 22t day one was better than t5 for the whole time i had i. is it perfect no but just started with box set up running a 9.5 cant seem to get the right gear and steering still is the typical losi push but ive not changed anything.
ashxxx is offline
Old 01-17-2016, 10:43 AM
  #1062
tedstryker's Avatar
Im running box set up in rear motor made couple changes. Went to 27 wieght oil in rear 32 in front running gear diff with 2k.With a shorty battery truck is very easy to drive great forward traction plenty of steering.
Old 01-17-2016, 10:47 AM
  #1063
Questions?? 22t 2.0 hub has a wear groove in it
I recently converted my 22t1.0 to a 2.0. And I broke a hub. Just for the heck of i looked at the other hub an noticed a groove in it that wasn't there when it was new. Any ideas what happened
. I took pix but I dunno how well you can see it.
donny939 is offline
Old 01-17-2016, 10:48 AM
  #1064
Another pic
donny939 is offline
Old 01-17-2016, 10:49 AM
  #1065
Last pic
donny939 is offline
