TLR 22T 2.0 Stadium Truck >
Old 01-01-2016, 01:14 PM
  #1021
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Originally Posted by StadiumRC
I have been out of rc for several months now and am thinking about jumping back in soon. If I am understanding things correctly, the only thing this truck really needs out of the box to be competitive is the brass pivot (if running MM) - right? It would be nice to buy a kit and build straight out of the box without requiring a lot of extras. Thanks!
That's it!
Aluminum ball stud washers are nice, but definitely not a requirement...
Frank Root is offline
Old 01-01-2016, 01:46 PM
  #1022
Originally Posted by Frank Root
That's it!
Thank you for the quick response. If I buy one pack of TLR aluminum ball stud washers will that cover the whole kit?
StadiumRC is offline
Old 01-01-2016, 01:55 PM
  #1023
TLRacing
Frank Root's Avatar
Depends on setup, but yes, it should in most cases.
Old 01-03-2016, 12:38 AM
  #1024
Can anyone tell me if there are sway bars available for the 22T 2.0. This is my first stadium truck and love driving it but we are now running it indoors on astroturf and the rear end is very loose and keeps spinning around on me in the corners. Does anyone have an astroturf set up?
I would really appreciate it. I have tried some things (heavier oil in shocks, standing the shocks up more) and had others at the track assist since I am relatively new.
Thank you
cheetahz24 is offline
Old 01-03-2016, 04:34 PM
  #1025
R/C Tech Elite Member
XXXDad's Avatar
Trader Rating: 198 (100%+)
Questions?? Post your setup
Please post your setup so we might better understand . Do you run Dragbrake in the ESC? Tires/Foams? etc....
Thank you
XXXDad is offline
Old 01-03-2016, 07:08 PM
  #1026
yoshgixxer's Avatar
Trader Rating: 78 (98%+)
Can some one link me to a setup sheet for med/high bite clay,in doors, semi smooth.
it has the sct rear hex's,brass rear hinge pin mount, other then that its stock, currently using 27.5 rear oil 35frt oil, has chain link fronts and dirt webz rears. 28/30mm ride height.
Truck works good, but pushes, Loose on throttle, Same tire prep i run on my otber cars and they are glued to the track.
Other thing it does annoying is if you over jump it wants to unsettle the truck .
Thanks!
yoshgixxer is offline
Old 01-04-2016, 12:53 PM
  #1027
TLRacing
Frank Root's Avatar
I bought the truck used and it has the sct rear hex's,brass rear hinge pin mount, other then that its stock, currently using 27.5 rear oil 35frt oil, has chain link fronts and dirt webz rears. 28/30mm ride height.
Truck works ok, but never really has alot of traction. Loose on throttle, and pushes around corners. Same tire prep i run on my otber cars and they are glued to the track.
Other thing it does annoying is if you over jump it wants to unsettle the truck very bad and spin it around.
Thanks!
Try this setup. I'd also HIGHLY recommend running the same tires (MFG/Tread/Compound) front and rear, as all setups from will reflect that. The tires could be causing most of, or all of, the setup imbalance.
http://www.tlracing.com/ProdInfo/Fil...etup,%20MM.pdf
Old 01-04-2016, 07:03 PM
  #1028
Hey Frank
Does this also apply for RM on loose clay/hard pack? Say 2wd buggy I'd use ribbed tires on the front, I don't want to do the same on the front of 2wd ST or SCT?
WagwanBumba is offline
Old 01-04-2016, 07:10 PM
  #1029
yoshgixxer's Avatar
Thanks for the reply. My setup is very close to that minus a fee minor things, ill switch it 100% and try same frt and rear tires. Also would me running shorty packs be part of the problem. Whats the best lipo size to run in this?
Old 01-05-2016, 01:37 PM
  #1030
does this truck have a 3 or 4 gear transmission
DIRT DIGGER is offline
Old 01-05-2016, 01:41 PM
  #1031
Trader Rating: 53 (100%+)
4 gear out of the box
GettinLapped is offline
Old 01-05-2016, 01:49 PM
  #1032
thank u sir
Old 01-05-2016, 03:40 PM
  #1033
tsair's Avatar
I used about that setup (+1mm on the front tower ballstuds) for broken in (down?) dirt webs, when I switched to new chainlinks I had to go +1mm on the rear shock tower ballstud and it was pretty dialed.
tsair is offline
Old 01-06-2016, 06:54 AM
  #1034
TLRacing
Frank Root's Avatar
3 gear for RM and 4 gear for MM.
Old 01-07-2016, 04:27 AM
  #1035
yoshgixxer's Avatar
Ran a brick pack and switched over everything to this exact setup, still running same chainlink/dirtwebz truck was 100% better. I could go lap for lap with my buddys mod buggy. Still wanna try running same/front and rear tires. See if i can really get it super hooked up. Brick packed seemed to be the bigest help
