TLR 22T 2.0 Stadium Truck >
Old 12-08-2015, 07:26 AM
  #991
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Originally Posted by MNiceGuy
The spoiler on my MM 22T is in very dire shape so I ordered TLR8120 since the spoiler on the MM body is not available separately. Looking at 8120, fitment on the RM body is a no brainer but how are you guys getting this to work on the MM body?
There might be something in the works....
Frank Root is offline
Old 12-08-2015, 01:24 PM
  #992
You're such a tease, Frank Seriously though, that's welcome news.
Christophoclese is offline
Old 12-08-2015, 04:37 PM
  #993
tsair's Avatar
The only thing I don't like about the 22T 2.0 is the TLR body is fugly. JConcepts Finnisher looks pretty nice (to my eyes) and you can buy replacement spoilers.
tsair is offline
Old 12-12-2015, 11:14 PM
  #994
MNiceGuy's Avatar
Thanks Frank. Mind you, that doesn't do much to solve my problem but as always I appreciate your prompt responses.
While I don't necessarily mind the different look of the TLR body, I might move over to JConcepts simply because the spoilers are separately and readily available.
MNiceGuy is offline
Old 12-12-2015, 11:16 PM
  #995
MNiceGuy's Avatar
Is there any way to get this truck to turn sharper on low-speed hairpins? I absolutely love my setup on jumps, sweepers, etc. but any time my track (new layout every week) has a lot of low-speed, sharp turns I simply cannot compete with the T5M (the defacto truck for my track) and its tighter turning radius.
MNiceGuy is offline
Old 12-13-2015, 08:53 AM
  #996
mo
mo's Avatar
Try lowering the front inner camber link ballstud. That will give it more initial turn in for those tight corners.
mo is offline
Old 12-13-2015, 10:05 AM
  #997
Default Ride height
What ride height is everyone running in their truck? In trying to copy some of the setups on the TLR site the spring adjusters are almost all the way down and I'm still not at 30mm.
Raced the truck for the 1st time last night. It ran great qualified directly into the main. Got into 3rdbut broke the stock rear camber block. It did slap the chassis on landings on take offs if I didn't hit the jumps perfect. To be fair other trucks were doing it also. Hence the ride height question.
ezimmerman is offline
Old 12-13-2015, 08:03 PM
  #998
Tiggertrucks's Avatar
Trader Rating: 68 (99%+)
What gearing do I need for blinky? Going to run at ocrc if it matters
Tiggertrucks is offline
Old 12-13-2015, 08:46 PM
  #999
tsair's Avatar
I'm running 30F/29R. What springs are you running, if you're running the buggy ones you'll need to get the +4mm shock cups.
For the plastic rear camber block, make sure your ballstuds are long and you can put grub screws into the unused holes to fill them up and strengthen the plastic.
tsair is offline
Old 12-13-2015, 08:54 PM
  #1000
Trader Rating: 137 (98%+)
Do ae truck wheels fit on the 22t 2.0
ashxxx is offline
Old 12-14-2015, 12:52 AM
  #1001
TLRacing
Frank Root's Avatar
No sir
Old 12-14-2015, 01:59 PM
  #1002
St class is coming back in my area so I bought a 22t mm I set it up to the spec sheet on tlrs site but I'm struggling with rear chassis slap which upsets the rear end and makes the truck get squirrely. What are my options to stop this?
mxmatt54 is offline
Old 12-14-2015, 07:30 PM
  #1003
Hey guys, I drove my buddy's 22t2.0 with the Mayfield Cactus setup in it and it felt really good to me. I was looking up the Kyosho springs and there are some differences. Can any one help me out on which ones I want. Thanks.
Front: XGS003, Short Front, Gold or XGS024, Medium Length Front, Gold
Rear: XGS012, long length rear, white or XGS035 rear, white
peeler_ss is offline
Old 12-14-2015, 09:48 PM
  #1004
tsair's Avatar
I'm using TLR5164 rear truck yellow springs instead of the kit TLR5167 buggy yellow springs. They're a little bit longer.
tsair is offline
Old 12-15-2015, 03:35 AM
  #1005
walterheard's Avatar
Trader Rating: 31 (100%+)
I've been seeing tlr cars with ae ball studs and ball cups. Is this illegal ? Does it work properly ?
walterheard is offline
