TLR 22T 2.0 Stadium Truck >
Old 11-19-2015, 11:08 PM
  #976
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Originally Posted by Mudcat981
Frank,
In the 22 3.0 video you mentioned the preferred frt/rear weight bios was 36/64%. What is it for the 22T 2.0?
I haven't scaled my truck lately. I run a brick pack with the brass rear pivot, and much truck is AWESOME.
Frank Root is offline
Old 11-19-2015, 11:52 PM
  #977
DriveItLikeYSIT's Avatar
Trader Rating: 93 (100%+)
Would you mind posting a few pictures of your 22t 2.0 chassis layout w/ a brick pack installed ?
DriveItLikeYSIT is offline
Old 11-20-2015, 10:11 AM
  #978
tlr discontinued part#tlr2973. All I really need is the crush washer that goes between the bearings in the rear hub. I was just wondering if the aluminum rear hub #tlr334014 eliminates the crush washer inbetween the bearings. It's hard to tell from the pictures but it looks like there's a lil indent replacing the crush washer..thanks for any help.
donny939 is offline
Old 11-20-2015, 11:17 AM
  #979
TLRacing
Frank Root's Avatar
I actually borrowed the ESC from my truck to another vehicle, so I can't get you a great photo ATM.
Replied to your PM.
Old 11-23-2015, 11:40 AM
  #980
starspike's Avatar
22t 2.0 mm is way better out of the box than my sct.. sct needed some help to get good but is now competitive.
starspike is offline
Old 11-24-2015, 03:38 PM
  #981
Can someone tell me exactly where you are to set the ride height ?? I think I might be doing it wrong.
Dirtraycer is offline
Old 11-24-2015, 05:28 PM
  #982
Mudcat981's Avatar
Here is a good video on the 22, the 22t will be the same points:
http://www.bing.com/videos/search?q=...9460887849B4B2
Mudcat981 is offline
Old 11-24-2015, 09:04 PM
  #983
yep I was setting the rear height in front of the tires . that would make a big difference. Thanks for the link !
Old 11-29-2015, 09:33 AM
  #984
jgroenhof's Avatar
Default Piston / Oil
Running pistons one size larger than I want to, 1.6/1.7 instead of 1.5/1.6. How much should I go up in oil weight?
jgroenhof is offline
Old 11-29-2015, 02:04 PM
  #985
Would it be hard or costly to change a 22sct to a stadium truck ?
sgtlt is offline
Old 11-30-2015, 02:18 PM
  #986
TLRacing
Frank Root's Avatar
5 at least, maybe 7.5wt.
Quite a bit, a lot of parts to change, including the chassis...
Old 11-30-2015, 05:07 PM
  #987
walterheard's Avatar
Trader Rating: 31 (100%+)
I see guys are running a shorty instead of a brick pack. How does this affect the truck ? Does a shorty make the truck perform better ?
walterheard is offline
Old 12-01-2015, 09:49 AM
  #988
TLRacing
Frank Root's Avatar
It makes is lighter and reacts a little quicker. As for team guys, most are still running the brick as far as I've heard.
Old 12-03-2015, 04:36 PM
  #989
We tried a shorty and Tyler didn't like it compared to a brick pack. Freed it up too much he said.
RandyJones is offline
Old 12-07-2015, 07:41 PM
  #990
MNiceGuy's Avatar
The spoiler on my MM 22T is in very dire shape so I ordered TLR8120 since the spoiler on the MM body is not available separately. Looking at 8120, fitment on the RM body is a no brainer but how are you guys getting this to work on the MM body?
MNiceGuy is offline
