TLR 22T 2.0 Stadium Truck
#961
And yes I'm running a saddle pack side by side which would be the same as a square pack with no adjustments fwd or rear.
#962
I have to say, kit setup is pretty darn good. I've been trying to improve upon it, but shorty in MM with kit setup and 27.5wt rear/brass pivot, is about as good as it gets. I was fighting a little bit of deceleration/corner entry steering, but realized I'm at 1 deg rear camber and not 1.5. I think that is the ticket to get better rotation into and through the corner.
And stock slipper spring will work on 13.5t motors. I'm almost at full spring compression of the spring, but it is working.
#963
I'm talking more of a turning radius than setup. When i'm going slow and try to make a 180 deg turn right or left. The turning radius is just to large and would like to turn sharper.
#964
FYI, I think they made a running change to the 2.0 chassis -- I bent mine and the replacement one I bought has extra milling and is presumably lighter as well --
#965
Frank, if you don't mind saying, which truck platform (stadium or short course?) sells in volume better now? I'm assuming this would affect the decision on which 3.0 would be released next.
From my limited sampling at our local track, 2WD SC is definitely drying out and ST is stronger and growing.
#966
#968
Even though I'd rather see the other come out first.
#970
#972
That said, I think SCT is rapidly losing popularity while ST is gaining popularity.
#974
After that it just a matter of choosing the right tyres.
